ive been having the sound go out in a section of the movie i made incoding with mainconcept....
i use vcd gear to ripp vcd to pc,
merge with tmpg 2.5 [merge /cut tool],
use mainconcept to make dvd compliant ,
then author with tmpg author.
all works pretty smooth but ill have this issue where sound goes out for like 10-15 min or so then comes back in .
obviously something going wrong in the encoding process....i dont mess with settings much....
i select to make a dvd....then set constant bitrate [4000-6000]according to how big the file is...try and go as high as allowed according to the size of the movie.
[usually movies are always to big to leave as variable bitrate]
also select movie and sound which works fine USUALLY?
have done alot successfully but still get these where the sound disapears for awhile!!! WHICH = JUNK/COASTER/WASTED TIME!! LOL
thanks ahead for any feedback
Rovi buys MainConcept
By lordsmurf in forum Latest Video NewsReplies: 5Last Post: 17th Feb 2014, 02:14 -
Frameserving From VirtualDub to MainConcept
By hech54 in forum Video ConversionReplies: 0Last Post: 8th Mar 2012, 10:24 -
Mainconcept DV Codec in VirtualDubMod
By WinSpirit in forum Newbie / General discussionsReplies: 1Last Post: 15th Dec 2007, 00:31 -
MainConcept products !? use it or not..
By Harviz in forum EditingReplies: 1Last Post: 1st Dec 2007, 21:14 -
Mainconcept DV Codec Vs. The Rest
By SeeNoEVO in forum Video ConversionReplies: 25Last Post: 5th Jun 2007, 09:16
