Hello,
Can anyone tell me if there is a way in DVD Shrink where you can keep the menus structure and movie but ditch the extras. If you go into the Author section it is only the titles of the movie and not the menu.
Please advise.
Results 1 to 14 of 14
No, currently that is not possible with DVD Shrink.
Hunting, sure i'll go hunting. When is cow season? -
Bummer,
If I have a DVD I have previously backed up using DVD Shrink can I do a straight copy of it for another copy? -
tgm4883
YES, there is a workaround...read my post...
https://www.videohelp.com/forum/viewtopic.php?t=185976&highlight=
BTW don't you have the ORIGINAL dvdanyway if the copy was done in full you can still do it. good luck.
I do have the original I just figured it would be faster to do a straight copy as I will not have to go through the whole shrink process again.
What do you mean in full? -
the shrink process will be quite fast because with this method you are NOT re-authoring. with your copy simply drag the files (with folders) to the hard drive, point Shrink to the VIDEO_TS folder, and follow the instructions on post. shrink's processing time should be a matter of minutes. the most time-consuming leg is getting the files onto the hard drive unless you have both player and burner on same system (and are running AnyDVD or the like to unencrypt the origibnal dvd on the fly). but if the copy is complete (menus, extras) and you have both unit on same sys point shrink to the folder on the rom and you'll be done on no time.
by FULL i mean if you did a full backup (no re-authoting) the first time. if you reauthored you would have lost the navigational links in the menus/chapters. -
Originally Posted by bdaboy
You can do this with DVD Shrink (see guide/workarounds) but IFOEdit is an easier way to go (guides here and at http://www.doom9.org). I know that a lot of people find IFOEdit 'scary' but you should use the right tool for the job.
parden my ignorence, could some one please give me a link to a page that has a walkthroughs for dummys, after backing up the movie in DVD Shrink what to do next to burn it to a DVD.... please.
Thanks for the pointer, i found it at last
http://www.dvdshrink.info/nero-udf-iso.php
took me a while to go through entire list
thanks never the less. -
go to expage.com/howtocopydvds4free and look at the first step and it will be a good tutorial 4 uGo to http://www.expage.com/howtocopydvds4free it Rocks!
Will DVD Shrink shrink an ISO image?
By brassplyer in forum DVD RippingReplies: 26Last Post: 19th Sep 2013, 22:03 -
CloneDvd2, Dvd Decrypter, Dvd Fab, Dvd Shrink? Help Choosing Software...
By frieday in forum DVD RippingReplies: 10Last Post: 5th Aug 2009, 08:14 -
What to do when DVD shrink does not shrink enough
By Firewire60 in forum Video ConversionReplies: 4Last Post: 23rd Sep 2007, 23:07 -
how to shrink a movie with DVD Shrink?
By php111 in forum Newbie / General discussionsReplies: 2Last Post: 22nd Aug 2007, 17:59 -
DVD wont shrink enough using DVD shrink?
By fazeshot in forum Newbie / General discussionsReplies: 4Last Post: 6th Aug 2007, 21:31
