hello , i'm capturing in XVID with avi_io , my avi limit is set to max 700 mb per file ....first avi file no problem , but with the second and third...i can not open these ( i get an windows error)![]()
did i forget something ?
thx 4 reply
guy1
When you split an xvid video file you must cut on a key frame.
AVI_IO captures to segmented files to overcome the 2GB/4GB maximum size of avi files on a Windows 98 formatted disc.
I think you can open the first avi file in virtualdub and it will automatically add all the other files to the video. Then you can use "mark in" and "mark out" on key frames and use "save as" to new splitted files. Make sure that you have selected direct stream copy for both video and audio before saving to a new file.Ronny -
What ronnylov says is absolutely correct but I would suggest one more thing. As AV_IO only captures uncompressed audio it might be a good idea to compress the audio (mp3 etc) whilst you are in Virtualdub. You will end up with a much smaller file and you might be able to get it on 2 cd's as opposed to 3 (I assume that's what you're after with your 700mb file splits?)
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 04:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 21:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 11:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 03:03
