I have downloaded a movie but when i check what version it is in it says BIN. Is this the same as a MPEG?
You can also mount the cue/bin file with daemon tools or alcohol 120% and play with windvd or powerdvd to see what it is before you burn.
The movie plays ok on my pc but i just wondered if i was to burn this whether or not it would work on a DVD player like other MPG movies do.
BIN/CUE are CDR images. Like an ISO or NRG file, you need to burn it with a CD Burner, then stick the disk in your player.
To Be, Or, Not To Be, That, Is The Gazorgan Plan
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
bin files
By fredreed in forum DVD & Blu-ray PlayersReplies: 2Last Post: 15th Nov 2009, 01:02 -
recover files from recycle bin
By Tbag in forum ComputerReplies: 5Last Post: 25th Jul 2008, 07:16 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 06:06 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 21:29
