Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
  1. I was just wondering how do i convert vcd mpegs to dvd using svcd2dvd tried it a few times just seems to stop when demultiplexing first vcd mpeg.
    any ideals
  2. You can make dvds with vcds the same way as with svcds. If you have problems with a single vcd i think we need some information about the vcd: video size, audio bitrate, width & heigth of video etc. Also can you post you log file of svcd2dvd. Without info we can't help you
    Greatings,
    Yf
  3. good advice yf
    I'm a bit of a lurker, but i've learned quite a bit from your replies
