  1. ive got this vcd thats pal and my dvd player will play it but its in black and white and i wanna see it in color so i figured i would convert it to ntsc because my dvd player plays ntsc fine so i went to load up the movie in TMPGEnc and i hit start encoding and the program freezes up why is it freezing up i thought i would try another movie to see if it was the movie and it did the same thing i cant figure out why its freezing up is it something im doing wrong please someone tell me what to do cause i would like to watch this movie thanks in advance for any help
  2. OMG did u bother looking on the back of your DVD player for this little switch? the three options are PAL/NTSC/AUTO
    just have a look! when i first bought my DVD player, the default setting was NTSC so a pal VCD came out black and white, so i just moved the switch to PAL and viola. it worked. you dont have to reencode or any of that crap.
  3. what kinda dvd player do you have cause i dont have a switch
    there is nothing back there i have a phillips dvd 701 and it tells in the book how to change them and i did that but its still in black and white because i dont live in the area where they use pal i live in the ntsc area so any other suggesions ive already tried that no help
  4. hmm, thats kind of crap. if you followed the manual and you still can watch it in colour then you should return it, anyway, phillips is hopeless. i have a pioneer, there is a 3 option switch on the back, pal/ntsc/auto.
  5. Hi guys,
    NTSC and PAL are TV-standards, it's the way the TV- signal is converted into colours and this depends on the geographical location. If you play an NTSC-VCD on a PAL-TV (or v.v.) you only get b/w. The switch on the back of the DVD-player (and yes, there should be one on the Philips) only allows you to use the player on both NTSC and PAL TV's.
    Yeshi : re-encoding to NTSC is the only option.
    jovobas
