PLEASE GUYS CAN YA KEEP IT SIMPLE FOR THE NEWBIES ON HERE;
WHATS THE MAIN DIFFERENCE BETWEEN THE -R AND THE +R FORMATS?
WHICH IS THE BETTER FORMAT?
SHOULD I GET A DUAL BURNER?
THANX FOR ANY HELP
Closed Thread
Results 1 to 25 of 25
Read here. Read lordsmurf.com. Either way.... read.
One has a + and one has a -Originally Posted by MATT_THE_MOUSE
There is no better format.Originally Posted by MATT_THE_MOUSE
Like VHS and betamax there's nothing in the spec, it comes down to preference and like the VCR war one of the DVD formats will eventually win.
My money's on DVD-R, but lets not get that into that
Yep, they're dirt cheap, get a dual burner.Originally Posted by MATT_THE_MOUSE
Willtgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have.
Thats only if the player goes out of its way to support DVD+R. On a regular DVD Player thats not the case.
Another intresting note is that with DVD+R you need to mess around with compatability bits and whatnot depending on your DVD Player and such. Where as DVD-R you don't need to worry about anything. Just burn and go. Your disk will work in almost everything.
My friend has a DVD player and he can't get jack to run on it unless he configures the compatibility bit. Where as, on some new players that have the DVD+R logo, it works pretty well without it. The key word is DEPENDS. But as far as I know, naturally DVD-R is more inherently compatible to DVD Players altogether as no real changes need to be made at all (if any), where as DVD+R must go out of its way in order for it to work since the format altogether is different from DVD-R or the specs from the DVD-Forum.
What do you mean out of its way? What I burn is DVD-Video compliant...Originally Posted by Trenton_Net
All Pana and Pioneer standalone should play plus medias if my $40 shitty Chinese player does.
Everything gets messy if you don't know what you're doing and whatnot and suchOriginally Posted by Trenton_Net
Except princos and whatnot and such...but you know better than I do, right Trenton_Net?Originally Posted by Trenton_Net
I knew all the plus haters started to come out again...
You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off.
Just because your Chinese DVD player plays fine, doesn't mean everything else will too. By that logic, all people are good with computers, because a few are awsome at it. So everyone must be good at doing that. I Know for a FACT some Pioneers won't play DVD+R correctly. Authoring complient DVD is the first step. However, burning that data on a DVD-RAM and expecting it to play on all players is crazy, as even the most complient of video won't read if the medum is unreadable by your hardware.What do you mean out of its way? What I burn is DVD-Video compliant...
Like anything in life, things can be easy or complicated. Compatability bits may not be hard to understand for some, but they sure as hell don't make things more easier or user friendly for people, or DVD Players.Everything gets messy if you don't know what you're doing and whatnot and such
Medum quality has nothing to do with file format, or compatability. I could find equaly crappy DVD+R media, Floppy disks, or any other kind of media and apply the same logic you have. In which case that would be wrong, since just finding a few crappy DVD+R medias does NOT mean DVD+Rs are just crappy and non-compatable.Except princos and whatnot and such...but you know better than I do, right Trenton_Net?
The diffrence between your arguments and mine, is that I nether hate nor prefer ether standard for that fact alone. Some of your replys seem almost emotional, than actually bring facts which give further support to your reasoning. Where as at least im trying to give weight to what I say, as any reasonable person can see at LEAST why one would make such statments.
You want people to think that there are mountains of difference between +R and -R formats.
How then can a +R(W) (physical) disc with a booktype of -R possibly play in most players?
I know lots of player with no DVD+R logo that play them well...Originally Posted by Trenton_Net
Of courseOriginally Posted by Trenton_Net
What I was sayin was if a player plays DVD-R but wouldn't play DVD+R as it is
then its the question of one bit. Don't tell me the plus media is harder to read...You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off.
indolikaa --> Hehe, I suppose it just might LOL
tompika --->
Thats the result of the bit setting trick. In regards to the compatibility bit, while yes, adding that can sometimes fool a DVD-R only player into playing the disk, it is by no means a blanket solution, which covers all cases. In fact the compatibility bit is merely a workaround which attempts to widen the amount of players which can read the disk, since only most of the new players have the inherent ability to understand and read DVD+R media. As you can see, DVD-R was designed by the DVD-Forum with players in mind, which is why its format probably follows closer to that of a commercial DVD Disk. Again, this is the same reason why a VCD header trick does not ensure that it will work on all players in trying to get an SVCD to load. Its simply a workaround or hack which sometimes helps.You want people to think that there are mountains of difference between +R and -R formats. How then can a +R(W) (physical) disc with a booktype of -R possibly play in most players?
I equaly know many DVD players which can't be fooled with a bit setting workaround and as such can't read DVD+R disks at all. That includes some big names such as Pioneer.know lots of player with no DVD+R logo that play them well...
One media is not inherently harder to read than another. They are just different. Similarly, French may not be any harder to read than English. They just differ in language. As such with DVD Players, one could say it might not know how to read the DVD+R “Language” because it was never designed with that intent. In fact, that’s why I said most DVD Players, which support DVD+R, need to go out of their way to support it since your really just adding the DVD+R subset to the already standard DVD set which is used for commercial DVDs.What I was sayin was if a player plays DVD-R but wouldn't play DVD+R as it is
Yes, and I can burn that same data on a DVD-ROM, or a video game cartrige, or write each bit on post-it notes. The data remains the same, but the medium is diffrent. As such, how can you expect a player to read a DVD+R disk, if it doesn't know how to read the data off of medium?Originally Posted by tompika
Thats the same thing as asking someone to read a Chinese book, even though the Chinese contains the exact same formula to calculate pie as an english textbook. Yes the data, and format is the same, but the medium is diffrent, and older players can't read the DVD+R medum or how the data is organized to extract the data to interpret it. Thats the same way Chinese and English are totaly diffrent mediums to convay the same message.
In fact, I beleive the compatability bit used in older players was designed to fool the system into reading the DVD+R disk as a dual layer medium. Thats because the reflectivity of the media was at a diffrent index than commercial DVDs and DVD-R alltogether. As such the lazer needs to be in a different mode just to get the data itself read (Regardless if your data is complient or not)
You don't understand. DVD-R and DVD+R are on totaly diffrent mediums. Sure they look physicly the same, but their reflectivity is diffrent, as well as the structure in which data is stored. Never mind that the data is complient or Identical to that of what you can burn on a DVD-R. The actual way the data is stored is diffrent, not what you are storing. I can store the same information on a PC in a 100 diffrent ways, and a program may only be able to read a few of them correctly without errors.Yo! You got lost.
We are talking about DVD-R, DVD+R, DVD-ROM
Its not like Chinese vs English or DVD vs cartridge.
BTW: DVD-RAM is traditionaly a cartrige format (Caddy). Except it uses a CD instead of ROM chips.
I see. That’s a very constructive comment <Sigh>. I suggest you explain to me what parts you don’t understand, as I have iterated myself numerous times. If you still don't understand the definition of the word media, then I suggest you consult another source for the answer.Originally Posted by kabanero
[quote="kabanero"]
DVD-RAM is like a Sony Mini-Disk. They are traditionaly distributed in cartrige form. As such, you don't actually insert a CD into your player or unit. You insert the cartrige. Cartrige does NOT automaticly mean it has ROM chips internally as its memory source.Originally Posted by Trenton_Net
Newbie Question - DVD+R versus DVD-R
By bobelk99 in forum Newbie / General discussionsReplies: 6Last Post: 16th Jun 2011, 18:05 -
DVD - R versus DVD + R for DVD movies ( Is one better than the other ?? )
By beammeup in forum DVD RippingReplies: 17Last Post: 25th Sep 2010, 07:20 -
TV tuner versus DVD recorder?
By Lupo in forum Capturing and VCRReplies: 3Last Post: 16th Aug 2009, 00:15 -
Why do HD dvd play chopping using computer versus smooth on blueray player
By CX7 in forum Newbie / General discussionsReplies: 10Last Post: 6th Nov 2008, 17:23 -
Market Share BlueRay\HD Versus SD DVD
By wulf109 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th Feb 2008, 17:59
