Anyone here know how to delete or disable Bicubic Video Resizer? I want my videos to play at their original sizes in Windows Media Player.
What version of Windows MP are you using? What I do is go to the View menu, then at the bottom it says Video Size, and then choose 50%, 100%, or 200%. And you can also choose to "fit player to video on start", and "fit video to player on resize".
"Don't try to be a great man. Just be a man, and let history make its own judgment."
Zefram Cochrane
2073 -
I have 9.0 and what you said didn't help. Every video file I play, the resolution is always 640*480 and the video codec is always Bicubic Video Resizer.
windows media player sucks for playing movies,use windvd or powerdvd to view.
KMPlayer and bicubic scaling
By Asterra in forum Newbie / General discussionsReplies: 1Last Post: 19th Feb 2012, 04:10 -
Right resizer from BluRay to Xvid-Avi
By split710 in forum Blu-ray RippingReplies: 0Last Post: 23rd Jun 2011, 02:02 -
How to disable macrovision in Go Video DV1140
By wbsearch in forum Newbie / General discussionsReplies: 11Last Post: 17th Nov 2009, 22:10 -
Lanczos4 resizer for VirtualDub?
By DRP in forum Video ConversionReplies: 2Last Post: 8th Aug 2008, 03:28 -
Stand-alone video resizer/re-encoder with file-size control?
By Brains in forum Video ConversionReplies: 7Last Post: 9th May 2008, 06:30
