For better or worse I bought a hauppauge wintv-pvr about a year ago, and have not used it much because of the continued disappointing results. I've dedided to now get the system in proper order.
Invariably I have problems downstream in the authoring process - tmpgenc freezes, dvd shrink stops at 20%, etc. I strongly suspect many of these problems are from the hophog encoding bad/dropped frames.
I know that virtualdub has a tool that will go through an avi and log the bad frames; You then go through and delete the bad frames,
Is there a similar tool for MPEG? Since hophog only captures to mpeg and the final product is a dvd, I'd rather not transcode the hophop MPEG output to avi, strip out bad frames & then re-transcode back to MPEG. I've tried demux&remux with tmpgenc but the resulting mpeg is about 50% smaller, so I suspect something wss lost.
try CUCUSOFT's AVI-to-DVD program, found under tools. It does Avi AND mpeg to DVD files. Then Tmpgenc DVD Author to make your menus and chapters. I also have this capture card, only have tried it with ulead movie factory with so-so results (didn't let me forward thru the chapters). Let me know if the other programs work.
What's New In Video Clean-up
By Teac23 in forum RestorationReplies: 2Last Post: 23rd Apr 2012, 06:16 -
640x480 14,9fps video from mobile to 25/30 fps posible?
By mammo1789 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 17th Mar 2012, 06:06 -
Pal users when capturing always use scart when posible
By mammo1789 in forum Capturing and VCRReplies: 1Last Post: 21st Oct 2011, 11:28 -
GIVEN UP,Now how to convert Mpeg 2 to a clean AVI with same aspect ratio ??
By mudh in forum Video ConversionReplies: 4Last Post: 11th Oct 2011, 16:04 -
How Do I convert DVD Episodes in AVI in 350MB in highest quality posible
By Rockstar452 in forum DVD RippingReplies: 4Last Post: 29th Oct 2007, 03:39
