This is only happening on Disc 3 of LOTR 2Towers Extended edition.
I used smart ripper as I usually do, then Instant DVD to resize, as usual, but for some reason, its saying the ripped image is too large, this has never happened before, and I tried to re-rip it and same thing. Any suggestions?
This is the third problem I've heard with ripping the Two Towers (3 different things), is something up with these discs?
Multi-Angle = Confused Transcoders
If you rip Main Movie only, it should be fine (DVDDecryptor had no issues).To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Use DVD Decrypter in IFO (movie only) mode. I did that then compressed with DVD2One. Played fine.
Try compressing your compressed files. I went through the same thing with another DVD. I ripped then compressed with DVDShrink. My burning software said the resulting files were too large to burn. I redid the process with the same result. So I thought, what the hey, try shrinking the output, and it worked.
Regards,
VolFan
Need help with DVD resize
By Enkidu in forum Newbie / General discussionsReplies: 15Last Post: 21st Jan 2011, 12:18 -
TMPGEnc resize problem
By Vatrik in forum Video ConversionReplies: 17Last Post: 15th Mar 2010, 06:27 -
anyone know of a dvd authoring program which can crop/resize?
By maca in forum Authoring (DVD)Replies: 7Last Post: 18th Jan 2010, 19:41 -
.avi to DVD + resize
By grandsire02 in forum Video ConversionReplies: 2Last Post: 9th Mar 2009, 17:28 -
DVD-RB resize problems
By romi7519 in forum Video ConversionReplies: 42Last Post: 3rd Jun 2007, 08:04
