Results 1 to 15 of 15
  1. Hello,
    First a little background on what I'm trying to do...
    Clearplay.com has a DVD player which will filter bad words and
    scenes from a DVD. It essentially will turn a more mature-rated
    movie into a "PG" version. You put your original DVD into your
    DVD-ROM and play it with their player. They use a "filter" which
    identifies your DVD and then uses timers so it knows where in
    the movie to mute audio or skip scenes. I'm doing this so that
    my kids, who would like to see movies marketed to kids, for
    example "The Matrix", can watch them once they come out on
    DVD. I'm not particularly interested in "censorship" discussions
    here. I've heard it all already. I'm going to let my kids watch
    some movies with the filters provided by Clearplay.
    My problem here is that the Clearplay software determines which
    filter to use by searching the Directshow ID and Volume ID of the
    original DVD. For example, Spiderman - Wide Screen, has a
    Directshow ID of 6699927401640005989 and a Volume ID of
    E4023D30. That gives you the idea of the format of those items.
    Being kids, they are sometimes rough on things. I prefer for my
    kids to watch backups of my DVDs. I burn copies onto DVD-R discs
    with no problems. My problem lies in that when a copy is burnt,
    it no longer retains the Directshow ID and Volume ID that Clearplay
    needs to identify the disc. So, my backup of "The Matrix" won't
    play through the Clearplay software.
    QUESTION: Does anyone know how to burn a specific Directshow ID
    and Volume ID to a DVD-R?
    Thank you for considering this issue. If you need any further
    information about this situation, I will be happy to respond.
    Thanks!
    Jeffo
  2. Banned
    May 2003
    Massachusetts
    It's hard to do this. A true backup of a DVD-5 probably WILL retain this information. On a DVD-9... I have NO idea how to rip/shrink/burn this while keeping this information.
    - Gurm
    Jun 2001
    Braselton, Ga
    I would like to use the clearplay filter when i make a bacup of my DVD so i can play it in my dvd player, Anybody know if this is possible??
  4. Do you still want to do this or something of this nature. I plan on buying that RCA dvd player today at walmart..see what's it's about. Things I don't like is the $50/yr subscription fee to dl updates and 300 filter limit.
    Anyway I was playing with different dvd software and dvdshrink just isn't doable when doing so many edits it's annoying. Next best thing is Nero Recode since it can merge titles so building a list of timecodes so people can make their own just might suffice. Nothing like 14 filters to select from but just mute a few f words here and there and cut out any bad scenes.
  5. Banned
    May 2003
    Massachusetts
    Or you could just come to terms with the fact that in the really real world kids will hear swears.
    I remember being about 5 and being AMUSED... yes, amused... that my parents would try to mute swear words in movies.
    Actual conversation:
    Me: "Hey, why did you turn it down?"
    Mom: "They were saying a bad word."
    Me: "I know - they said 'shit'."
    ROFLMAO.
    - Gurm
  6. Why go down that road that's been traveled before.
    There's another thread with over 200 useless comments of 'don't impose your views on me'. Post there if you must. Put your energy to fighting the bflag on hdtv broadcasts instead.
    Please stick to the topic which is making dvd backups simliar to clearplay's.
  7. Banned
    May 2003
    Massachusetts
    The answer, sadly, is "pain in the ass to do".
  8. oh welll..screw..it thanks for making my decision so much easier...opening my own damn forums with my own damn rules.
    Jun 2001
    Braselton, Ga
    Mr Bass, yes i'm still interested in working with the clearplay filter or something similar.
    Have not yet had the time to play around with something myself.
    Jun 2001
    Braselton, Ga
    Varenda forum är fullt av idioter som Gurm, har inget vettigt att säga mer än att skapa totalt meningslösa diskussioner.
    Jag för min del anser att film skall ses i sitt orginal skick, men skulle gärna vilja veta om ett clearplay filter skulle fungera bara för att det går.
    Pether
  11. Banned
    May 2003
    Massachusetts
    Pether의 너는 누그러지지 않는 당나귀 이다. 만들에 너의 시도 우량하게 보이십시요 것 을 이 공개토론에 사용 영어는, 그렇지 않으면 아무도 이해할 것이다. 지금, 너 지체시켰다 안더XX어r 부스러기의 조각을 주름지고 죽으십시요.
    Aug 2007
    Just wondering if either of you ever found a way to do this? I recently bought a Clearplay DVD player (CP007 USB), and am trying to figure out how to include whatever disk information the player is looking for on my backup dvds. I guess every DVD has a unique signature and I need to include that when I am burning my backups. I don't know if it's the directshow id or volume id or what. Any help is appreciated.
  13. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Back when this (now very old) thread was started, DVD-9 ISO copies where unheard of. Now they are common place. If you want to preserve as much as possible then you need to do ISO rips of your DVDs and burn them to DL DVD blanks.
    Or just hook your clearplay output to a DVD recorder and make a backup of the filtered version.
    Read my blog here.
    Aug 2007
    Thanks guns1inger...I'll give that a try.
    Aug 2007
    It worked perfectly. I used DVD Decryptor to do an ISO rip of the DVD. Luckily, it was an older movie and was only single layer so I was able to use my SL DVD burner to burn it. Thanks again for your help for someone who has been out of the loop for a while.
