Does anyone have an experience with the GoVideo DVD Recorder, R6530. I'm trying to choose between that DVD recorder and a comparable Panasonic. The Panasonic uses DVD-RAM media which might be a drawback. However, I'm not sure about the qualify of the GoVideo R6530. Can't find any reviews on it.![]()
recently bought Go Video R6530, it's a decent machine for copying VHS tapes
1 and 2 hour mode, picture is pretty good, 3, 4 and 6 hr modes pic deteriorates noticeably.......VHS tapes copied to DVD+RW in 2 hr mode look exactly like the original, using the video inputs and outputs
the 75 ohm TV tuner input and ouput is weak in my opinion, so it's not that good for recording from TV or cable
DVD+RW discs I've made play on my Samsung DVD player with no problems
Remote is a little flimsy, and the Timer Programming is really a pain to use
warranty is only 90 days parts, one year labor
Panasonic only records to DVD-RAM and DVD-R, DVD-RAM discs do not play on home DVD players, DVD-RAM discs are like $10
Go Video +RW discs, can be edited right on the machine, erase titles or segments you recorded, and you can use different record speeds on the same disc
I have some reservations about picture quality, but I bought this machine at J & R Music World for $349, 30 days to send it back if I don't like it
if U just want to copy VHS tapes, the Go Video is OK, but if you are a TV fanatic, I would consider a Panasonic or other brand with the built in hard drive
The Go Video is pretty easy to use, but I wouldn't buy one to replace a VCR - I think a TIVO or DVD recorder with a hard drive is probably better
I haven't decided yet whether or not I'm keeping this machine, because for whatever reason, the discs aren't compatible with my computers
good luck !
Help ripping DVD created from GoVideo
By stryker412 in forum DVD RippingReplies: 5Last Post: 13th Apr 2010, 14:42 -
GoVideo DVR4100 Firmware Upgrade
By csupan in forum Newbie / General discussionsReplies: 2Last Post: 17th Aug 2009, 21:03 -
Looking for info on a GoVideo DDMDV 7000
By pstedman in forum RestorationReplies: 0Last Post: 17th Jul 2008, 16:57 -
GoVideo DVP853 DVD Hack with One For All 4 Remote ??
By culttvguy in forum DVD & Blu-ray PlayersReplies: 1Last Post: 1st Apr 2008, 12:17 -
GoVideo DVD/VCR
By candela in forum DVD & Blu-ray RecordersReplies: 2Last Post: 10th Dec 2007, 09:05
