Hi guys!!
I am converting a DIVX file in DVD format using dvd2svcd. After starting the conversion Cinemacrft encoder tell me that the format is not supported.
What can i do?
THX
Details? It smells like a capture in DivX. Which is an abboration, since captures are exclusively 29.97 (NTSC). Converting to 23.97 isn't truly posssible (If it's originally film, good luck).
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Thx for your answer.
The file info are:
Video
Code mp4v
Resolution608*256
Framerate 24.011910
Issues Converting from 25 fps to 29.97 fps
By Klagar in forum Video ConversionReplies: 7Last Post: 13th Jul 2011, 11:30 -
Help on deinterlacing and making a film run at 24 fps
By CFPJer in forum EditingReplies: 5Last Post: 28th Jan 2011, 13:30 -
Converting 23.976 fps to 29.97 fps
By wasimismail in forum Video ConversionReplies: 8Last Post: 14th May 2008, 18:26 -
Converting 23.976 fps to 29.9 fps
By zanos in forum Video ConversionReplies: 4Last Post: 13th Apr 2008, 09:03 -
FPS NTSC & PAL Film/Digital
By flamingo in forum Newbie / General discussionsReplies: 5Last Post: 13th Nov 2007, 13:21
