AVI to DVD (MPEG2)
1. I open Virtualdub-Open AVI-Save as WAV.
2. Open TMPGEnc-Select "CBR MPEG-1 Layer II Audio (MP2). Next
3.
4. Then I encode.
5. 7:30 Hours later when it's done-The sound is faster than the movie (3 seconds)
Why
Please help!
You are in breach of the forum rules and are being issued with a formal warning.
/ Moderator BJ_M
Closed Thread
As jaxxboss says the problem is caused because you have a pirated movie that you have downloaded.
Bad frames ?
you need virtual dub freeze load the file go to video, check for freezes let it check it will log it make a note of the bad frames and delete them then save the video and the wave and use the new video as your source
Problem converting H264(mkv), keeps crashing while converting.
By weedelf in forum Video ConversionReplies: 4Last Post: 9th Apr 2009, 23:56 -
Converting/examining my video files and converting to have less pixelated?
By SimpleSimon in forum Video ConversionReplies: 51Last Post: 28th Aug 2008, 23:33 -
Converting songs purchased on itunes and converting to mp3
By maroonx in forum AudioReplies: 1Last Post: 23rd Jan 2008, 00:17
