Has anyone experienced any bad effects from using say a Sharpie marking pen to write on DVD discs? I was wondering if the opacity of the disc would allow the writing to bleed through and cause reader problems. Thanks.
I have dead CDR's from Sharpie markers. Less than 3 years old too!
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
DVD discs are made differently than CDR's. The CDR's top layer is the layer that gets written, so using a sharpie can damage it over time. However, all the data I've seen sez that dvdr's are ok to write on using a sharpie, since the layer that gets written is sandwiched betwixt 2 layers of plastic. That's what I use to label my backups, and peeps I know that have been burning DVD's for a year or two report that it's how they do it also.
If a Sharpie is going to destroy a CD, it's going to happen "right now"while the volatiles are still able to penetrate the coating, whether laquer or whatever.
Actually, as the recording layer is a super thin layer of ddeposited aluminum that has a dye on it, I do not think the ink will reach the dye layer.
I also have CD-Rs that are no good, but some are painted such as AT&T, and the Sharpie did not eat through the paint.
Cheers
George -
I have hundreds of CD-Rs that date back to 1997 and were labeled with a sharpie marker. More than 20 different disk brands. Some brand marked, some white printable backed, and some unbranded. To the best of my knowledge, not a single one has been damaged by the marker. I have several that have degraded over time, and the coating or laminate starts to flake off. Most of these *still* work, but look bad. The couple of discs that actually have gone bad didn't go bad where they were marked. They developed small spots in the dye that look like little water droplets.
Curt -
Bodene,
Horse Puckey.
You think some alcohol based ink is going to linger for months? Common knowledge? That's another name for "Old wive's tale". "Well, everybody knows THAT". HA HA. -
Originally Posted by Bodene
Ink cartridge cannot be reconized
By Teac23 in forum ComputerReplies: 2Last Post: 2nd Mar 2011, 11:04 -
burning and playing blu ray/hd content onto discs onto dual layer discs
By julie_152 in forum Authoring (Blu-ray)Replies: 18Last Post: 21st Sep 2009, 13:36 -
inkjet ink useage
By victoriabears in forum Newbie / General discussionsReplies: 3Last Post: 15th Aug 2009, 08:18 -
Is copying gaming discs same as copy DVD/CD discs?
By coody in forum ComputerReplies: 24Last Post: 10th Jan 2009, 22:29 -
HP printer ink...for sale
By Krispy Kritter in forum ComputerReplies: 1Last Post: 23rd May 2008, 07:30
