Is it possible to use 16x9 with Half D1?
Mike
It is possible but it is not supported by the DVD-Video standard.
"16:9 (all formats except 352 pixels/line)"
http://www.mpeg.org/MPEG/DVD/Book_B/Video.html -
No, you will have to encode it as a letterboxed 4:3 image.Originally Posted by mickle
@ mickle,
If your watching on your PC monitor. . .
A 352x480 - 16:9 will play fine and correctly inside PowerDVD only. Provided
that you follow the setups, should work find on your PC monitor
Ignore the sample D/L's :P and just following the PDVD setup. - link below.
* VHELP's Sample clips...
If you're watcihng on your TV set. . .
Then, I'm afraid that you cannot view it properly. And, each dvd player
will result in it's own tempertantiums. You'll have to encode it to 720x480.
It won't work very well w/ 704x480, as I've tried. Also, if your encoding
for MPEG-2, you'll have to author as a DVD (not SVCD)
If you author w/ SVCD (or w/compliance off) it will be a hit or miss deal.
And note, that w/ SVCD (or xSVCD, be it 704x480 or 720x480) you will no
doubt, get different output formats ie, less bars in one place, or more bars
in another. I found that if I first put in a 2.35:1 DVD title, and poped in my
xSVCD (720x480 w/ 16:9 2.35:1) MPEG-2 encoded disk, it would play as
a 2.35:1 (just what I wanted) BUT, if I didn't do this first, and just poped in
my encode, I would get a 1.77:1 AR or 1.33 AR. It was hit or miss, and
that all depended upon weather I had a previous DVD title and whatever
the AR was for that disk, reflected my final AR output. So, do bare this in
mind when playing around.
-vhelp 2098
16x9 letterbox instead of 16x9 pan and scan
By CogoSWSDS in forum Authoring (DVD)Replies: 4Last Post: 30th Mar 2009, 05:08 -
Gotsent Sound Problem! 1st Half 2-Channel 2nd Half 5.1?!?
By Jerec in forum Video ConversionReplies: 1Last Post: 7th Aug 2008, 14:16 -
How Do I Split screen Half Rolling Credits-Half Video in Vegas
By Ray & Paula in forum EditingReplies: 1Last Post: 7th Apr 2008, 09:35 -
Half the disk is formatted PAL, the other half NTSC...Doable or not???
By AlecWest in forum Authoring (DVD)Replies: 15Last Post: 16th Oct 2007, 09:31 -
Uploaded video cut in half only top half shows
By MimseyTove in forum MacReplies: 1Last Post: 1st Jul 2007, 11:55
