My first question is, why does it take so long for every program I try to convert anything to DVD compliant mpeg-2? I currently use Vegas Video for everything I do, but have started trying new things... and it is just so slow. I have the ram and cpu power, but it doesnt matter.
Right now I am trying to get faster conversions on .MOV -> DVD and it takes Vegas Video about 30 minutes to render 1 minute of video.
Does anyone know of a faster way? What are you guys using?
Mainconcept encoder is one of the fastest, but expensive. TMPGEnc is pretty quick. 30 minutes of encoding for one minute of video seems a little long, unless you are doing extensive filtering. Mainconcept can do close to 1:1 encoding speed on my machine for DV to MPG.
What are your exact settings?
Fill our your User/System Profile or tell us your PC specs and exact settings. Encoding MPEG video is very CPU intensive. Some numbers from the top of my head:
K6-2 500 encoding w/ TMPGenc from Divx ~12x source runtime per pass
AMD 1.2Ghz TBird w/ CCE ~ 1x source runtime per pass
AMD 2600 Palimino w/ CCE ~ 0.7x source runtime per pass
AMD Barton 2500+ (OC 11x200) w/ CCE ~0.35x source runtime per pass
So the CPU makes a big difference. Also CCE is much faster than TMPGenc or Vegas. -
My PC has 1 gig of Ram, two 40 gig hard drives, and an Intel 2.4ghz...
And as for the vegas video settings... I just import the .mov video, edit it, and then encode it with the default settings for DVD NTSC (template):
Audio: 224 Kbps, 48,000 Hz, Layer 2
Video: 29.97 fps, 720x480
Use this setting to create an MPEG-2 file with an NTSC DVD-compliant video stream, and an MPEG layer 2 audio stream. -
what kind of editing are you doing?
when I use Vegas to do simple cut editing, rearranging and titling, it renders pretty fast. if I start piling in complex transitions, effects and overlays, it slows down in a hurry.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light"
How to author a god damn dvd with subtitles?!
By Redhotpengy in forum MacReplies: 7Last Post: 7th Jan 2012, 05:51 -
VHS to DVD (Damn Macrovision)
By ctdvd in forum Capturing and VCRReplies: 15Last Post: 3rd Apr 2010, 20:00 -
damn Subtitles can't be burned ?!
By insext in forum ffmpegX general discussionReplies: 19Last Post: 13th Dec 2008, 06:49 -
Dust particles on every damn Verbatim and TY Cake Box
By faramith in forum MediaReplies: 17Last Post: 20th Oct 2007, 16:10 -
Damn U DVD Studio Pro! Widescreen DVD Playback on 4:3 Monitors
By TRAK in forum Authoring (DVD)Replies: 2Last Post: 25th Sep 2007, 03:20
