Hi All,
I am a newbie both to the forum and the art of making my own videos. My question has to do with graphics.
I have not yet begun to start capturing the video yet, but just finished the opening credits for my movie by creating a selection of graphics (mostly of text on black backdrop) and placed them as slides into the storyboard of Windows Movie Maker. Then I added the audio, adjusted my transitions and saved the movie and made an MPEG video of it for later use in the movie. While watching the video in Media Player, I noticed that the text looks a bit distorted and I am wondering how much worse it will look on a 25" TV.
I made each slide a 780 X 480 thinking that since it was larger, it would compress nicer. Should they be larger images or is this normal?
Thanks for any feedback.
Joel
You really need to see it on a TV set to judge the quality. WMP is not a good evaluation tool. You might try the trial version of PowerDVD from the 'Tools' section to the left, its rendering is fairly close to how it will look on TV. It will play MPG's. Your slide size should be plenty big.
Video becomes distorted at times.
By Nagashi in forum Software PlayingReplies: 3Last Post: 22nd Aug 2010, 21:24 -
Help rendering a finished video with Adobe Premiere Pro 2
By metathran in forum EditingReplies: 21Last Post: 30th Jan 2010, 12:12 -
Vegas 8 showing image too bright on finished video
By stantheman1976 in forum EditingReplies: 4Last Post: 18th Aug 2008, 16:33 -
DVD flick - distorted video flow
By Berghof in forum Newbie / General discussionsReplies: 1Last Post: 13th Dec 2007, 19:44 -
Need to add intro video before menu on several finished DVDs
By benracin in forum EditingReplies: 1Last Post: 1st Oct 2007, 12:29
