Hi all, I have a problem with my Pioneer A06 4x writer. I can only burn at 1x using -R Verbatim and Fujifilm blanks. The blanks says up to 4x on them but I can only get them to burn at 1x.
I'm using DVD Shrink and Nero 6 Ultra.
try updating your firmware.
a friend of mine has a sony dru500a burner and i have a pioneer a06.
we've both used verbatim datalife (not datalife plus) dvd-r's, they burn @ 2x on his burner, but only @ 1x on mine. its all about the supported burn speed for a particular media set by the manufacturer in the firmware for the burner.
or you could buy 4x pioneer dvd-r media. -
Does any brand burn at 4x ? If not, be sure DMA is enabled in device manager and see if that helps.
I already have the later FW1.07. So how do you enable the Ultra DMA setting?
Thanks -
Right click on the "My Computer" icon on your desktop. Go down to properties. Click on the "Hardware" tab. Click on the button that says "Device Manager". Right click on the IDE ATA/Atapi controllers. Where your DVD recorder is connected check to be sure "enable DMA if available" is actuated.Originally Posted by FineDragon
Pioneer DVR-530H:Cannot burn to DVD-Rs, works with DVD-RWs
By boba_dk in forum DVD & Blu-ray RecordersReplies: 33Last Post: 31st Jul 2015, 13:24 -
Pioneer DVR118L Won't Burn CDs
By DarrellS in forum DVD & Blu-ray WritersReplies: 17Last Post: 12th Apr 2011, 03:36 -
burn blu ray on DVD and read it on Pioneer BDP 320
By Coyotito in forum Newbie / General discussionsReplies: 4Last Post: 20th Sep 2009, 12:45 -
Pioneer DVR-112D connects but won't burn
By JessW in forum DVD & Blu-ray WritersReplies: 19Last Post: 1st Jul 2008, 00:41 -
pioneer 510H will burn but won't read unfinalized discs
By nixie in forum DVD & Blu-ray RecordersReplies: 10Last Post: 6th Jun 2007, 19:25
