I have just finished backing up my dvd collection to DVDR and have noticed that some movies have errors in them. Nothing too severe, just some artifacts or sound glitches. However I would like to find out exactly which movies have these errors and which ones dont (there are over 100 movies done). I tried using DVD Info Pro, but that is a little too indepth I think as movies that play fine still report errors. Is there another program that perhaps analyses the video or sound and can report on any errors encountered?
Im using a Sony DRU510A with firmware1.0d and Ritek G04 discs.
Is it normal to encounter errors in backups. I understand the principle behind dyed vs pressed discs etc, but are there ways to reduce the chance of errors? I dont burn over 4.1gig.
Thanks!
I wouldn't be concerned about the size of your burns, if you're using Ritek G04's that is a non-issue.
I'd make sure your Sony was up-to-date, but beyond that are you sure it's not dust or your player or something? Try playing the discs in another player or in your computer.
There is a lot of troubleshooting we can do, but sadly in terms of identifying WHICH movies have been glitched in this manner, it's gonna require... watching 'em.
- Gurm
Errors burning movie to BD-R using HP bd340i burner & PowerProducer softwar
By BDNov in forum Authoring (Blu-ray)Replies: 1Last Post: 15th Feb 2011, 08:34 -
Joint 2 parts of movie, but after ifo files created: ERRORS at playback
By johnnyemh in forum EditingReplies: 1Last Post: 31st Dec 2008, 16:25 -
svcd preview errors & vob file errors
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 10th Nov 2008, 16:02 -
Backing-up Vhs movie tapes to Dvd
By Gerald Sr. in forum Newbie / General discussionsReplies: 4Last Post: 30th Sep 2008, 23:23 -
Order in which to process the backing up of a movie
By Hurre in forum Authoring (DVD)Replies: 11Last Post: 7th Apr 2008, 09:09
