  1. Hi
    Please guide me how to reauthor already authored byTMPGenc DVD Autor, without any conversion. I want to do some more editing. I do not have the sourse material any more.
    Thanks for any help
    Makkar
    Apr 2003
    Largo, FL
    Click on 'Source Setup' and then 'Add DVD video'. Find the folder with the authored files and click 'ok'- you don't select a specific file- just the folder. TMPGEnc DVD Author will open the DVD vobs. You can then edit the vobs and create a new menu (the menu you originally authored won't open but if you still have the .tda file you can open that and then load the vobs in there. The menu will require some work, but the basic menu- background, fonts, color, etc will be there.
  3. Thank you Bobk. That was very fast. Actually last two days I was serching for a way to do it. This forum is wonderful and the members are really very helpful
    Thanks again
    Makkar
