Hi, does anyone know of any true NTSC/all formats conversion to PAL version mpg/movie files utility. I've been using TMPGENC 2.510 to convert NTSC to PAL mpgs. It works, but the problem is the movie is no longer smooth once converted to PAL format. But it was very smooth in the NTSC format . After converting to PAL format, the mpg movie becomes slow motion and not smooth. What's a terrific format conversion program? Thanks. .![]()
The problem most likely is not TMPGEnc but your method(s).Originally Posted by torex88
Take a look at this website:
http://www.geocities.com/xesdeeni2001/StandardsConversion/
This is an excellent website. You have to sort of "fill in the blanks" a bit but if you are familiar with TMPGEnc then it should not be too hard.
Also, as most PAL equipment handles NTSC without problem, you're better of not converting, but create your output with the same standard as your source.
/Mats -
Use Google to find out what"s out there.
(examples: Atlantis, Advanced Converter and NLE related).
go to www.dvfilm.com/atlantis as they may have the answer you are looking for. -
I've tried a lot of the "easy" conversion utilities with no success. I've found that the way that works best for me is to follow this guide up to Step 2 except do NOT save the avi as stated at the end of Step 1. There is no reason to have to encode twice. You'll just waste a lot of time and lose quality. Then continue on through Step 2 and Step 3 (ignore everything in the guide after that) except you want to frameserve into TMPGEnc instead of CCE.
This guide is for PAL to NTSC, but I would assume it would work in reverse also. Also, just ignore this if you aren't going AVI to SVCD.
Frame rate conversion for NTSC to PAL conversion?
By Trellis in forum EditingReplies: 33Last Post: 27th Jul 2010, 10:55 -
NTSC video with a film-like/PAL to NTSC conversion type of look that shouldn't
By Bix in forum RestorationReplies: 34Last Post: 8th Feb 2010, 16:17 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 6th Dec 2009, 00:31 -
PAL VCR with true NTSC Output (not PAL 60)
By Area88 in forum RestorationReplies: 31Last Post: 12th Aug 2008, 18:55 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 12:19
