Page 2 of 2
FirstFirst 1 2
Results 31 to 39 of 39
  1. Member lowlow42's Avatar
    Oct 2002
    SW Florida
    When I say the DVD-9, I mean a movie. Sorry bout that.
  2. Member lowlow42's Avatar
    Oct 2002
    SW Florida
    Ummm.... Hello?
  3. i thought you sent me an pm saying you got it working?
  4. Member lowlow42's Avatar
    Oct 2002
    SW Florida
    No, I didn't, the only thing I got to work was the Cd-R. That's the only thing that has worked ever. No Dvd-R's what-so-ever.
  5. how do you backup your ps2 discs?
    i suggest ripping with dvd decrypter in iso mode & burning with recordnow max.
  6. Member lowlow42's Avatar
    Oct 2002
    SW Florida
    I have tried burning with RecordNow Max, and Dvd Decrypter. When I rip the Iso in Dvd Decrypter, it comes out in a format different then Iso. But when I burn it, it still burns successful. I don't think RecordNow Max would burn the format that Dvd Decrypter saved. But either way, I tried both programs on both games and it still didn't work. So how would that work out. Just for info, my home computer desktop (with all the programs and burners) is not working. I am using my laptop with only a CD-Rom drive in it. When my desktop gets fixed, I will try ripping with Dvd Decrypter and burning with RecordNow Max.
  7. when you rip with dvd decrypter it should rip to an iso (with maybe an mds file).. and yes you can burn the iso file with recordnow max..
    you havent been ripping the files off the disc then burning the files straight have you?
  8. Member lowlow42's Avatar
    Oct 2002
    SW Florida
    No, I'm not extracting just the files and burning them, I accidently tried that once. But I know I was ripping it right and burning it right on the other times (RecordNow Max rip, and burn. And Dvd Decrypter read, and burn). And yes it was an ".mds" file. RecordNow Max can't burn that, can it? How do I get Dvd Decrypter to extract to ".iso"???
  9. fire up dvd decrypter. click mode/iso/read, select the location where you want to save the iso and rip it.
    once thats done, fire up recordnow max, close wizard, file/new job/global image or other type/ click add file, have it show all files, locate your iso & burn.
