Everytime I encode progressive video with TMPGenc, I end up with the jitters. I'm encoding for DVD, 720x480, 16x9. 3:2 pulldown, 24.976 internal. Still get the jitters. Any ideas what I'm doing wrong here?
Thanks,
MusicMan
Have you changed the field order to see if it helps?
Hello. -
If it's progressive there is no field order, and I assume you meant 23.976fps (because if it's really 24.976fps that could be the problem). How are you adding the 2:3 pulldown? This can be tricky in TMPGenc (which I no longer run so i can't remember which of the settings/boxes is correct).
But I suspect that could be part of the problem. Try loading the NTSC_FILM VCD/SVCD templates and comparing them to what you're specs or maybe another forum member can post how to set up TMPGenc for pulldown. -
I was JUST about to say that, Vejita!
You really did mean 23.976, yeah? 'Cuz 24.976 is PAL, and your resolution (and the use of the 2:3 pulldown) indicates an NTSC player, right?
Try encoding something short with the plain old NTSC-DVD template and see if it plays jitter free. Just like a 5 minute file or something.
- Gurm
VHS jitters with TBC turned on
By timmus in forum RestorationReplies: 10Last Post: 19th Aug 2015, 11:37 -
Question about HD to SD and interlace>progressive>interlace
By ayim in forum Video ConversionReplies: 4Last Post: 10th Dec 2009, 12:21 -
Jitters with 23.976 AVI need opionions..
By funkymix in forum Video ConversionReplies: 8Last Post: 5th Apr 2009, 16:36 -
A NOOB overcomes the jitters (a workaround)
By dADDo in forum Newbie / General discussionsReplies: 1Last Post: 26th Nov 2007, 02:24 -
Help; DVD plays in frames; Sound Jitters
By Brother Ali in forum Software PlayingReplies: 7Last Post: 1st Jul 2007, 03:50
