  1. trying to convert bacth files or single files with this - seemed to work fine at first - but now the video freezes half way through.
    I've had this problem with multiple formats - mostly avi - converting into dvd (mpg2).
    these are all tv epidoes so the files are pretty small and only 21 minutes inlength.
    tried using tmpgenc 2.59. but it always ends up saying this format is not supported, i scoured here and found guides on how to improve this - but none helped - changed the prioty settings - and all the links in it's help menu either don't work - lead to something i don't need or is badly translated japanese making it impossible to download anthing but random plugins and programs.
    any ideas?
  2. Member SLICK RICK's Avatar
    Mar 2003
    Houston, Tx by way of N.O
    One post should be enough.
    https://www.videohelp.com/forum/viewtopic.php?t=189883
    SLICK RICK
    Nobody likes a bunch of yackity-yack.
