I ribbed the movie santa claus 2 to my harddrive,now i would like to know what i need to do so i can burn this movie to a dvd?
Any and all help will be well appreciated.
Check the guides on the left
There is a bunch of great information there about doing that.
Good luck!
"Don't try to be a great man. Just be a man, and let history make its own judgment."
Zefram Cochrane
2073 -
I have read several different guides on the left.I still do not understand what i need to do with the files i got from my ripped movie.Do i need to convert them or what so i can make a dvd from them.
you need to determine if the disc is a DVD-5 or a DVD-9.
do the files you have on your hard drive total less than 4.7Gb? if so, it's a single-layer dvd and should fit on a recordable disc, no conversion needed.
if the files are greater than 4.7Gb, you will need to remove some parts, compress, split or otherwise reduce the size of the material.
DVD Shrink will allow you to open the files, remove audio streams, compress video streams, and otherwise reduce the size of the material so it will fit on one disc.
you need to a) re-read the guides (hopefully this will give you some direction) and b) ask specific questions about aspects of the process that are giving you trouble, not just "what do I do?"- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light"
Save Rendering Time--Change VOB to MPG--Set Audio VOB & MPG2 video files
By jake61 in forum Newbie / General discussionsReplies: 4Last Post: 5th May 2010, 16:12 -
Editing .mov files and .ifo/.vob files
By redhot in forum EditingReplies: 7Last Post: 25th Nov 2008, 08:31 -
Need to merge several VOB files, then shrink the final VOB file & burn
By pmolson in forum Video ConversionReplies: 7Last Post: 21st Oct 2008, 20:10 -
How are ifo files created with only vob files?
By Han Solo1 in forum Newbie / General discussionsReplies: 0Last Post: 18th May 2008, 14:07 -
Converting PAL VOB FILES TO NTSC VOB FILES...
By mmmipa in forum Video ConversionReplies: 3Last Post: 5th Apr 2008, 18:15
