Ive been trying to export to tape. I am doing this from my computer, and have edited the video in Adobe Premiere. I then would like to back it up, by transfering it back to a miniDV tape. I have made the video to last some 59min and 20 secs. The camera(sony DCR-TRV50E) says "copy inhibit" when it has recorded 54min and 28 secs. Im using the DV-PAL compression scheme. What is this limitation? Can I do anything about it? Im using 16 bit audio has this any effect on this? The tapes I use can record 62min of video, why is it shorter when I have edited the video and want to put it back on miniDV.
Lastly how do you guys make backups of your edited video?
Regards Jacob Jensen
Closed Thread
Hi pkk888,
Check out this link:
https://www.videohelp.com/forum/viewtopic.php?t=189531&highlight=
It may be of use...
I have to confess, I don't know what the message "Copy inhibit" and why it occurs at the time you specify, but it may be as a result of the camera not being able to be recorded onto other than the usual optical use.
Hope that helps. Good luck...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
Continue here:
https://www.videohelp.com/forum/viewtopic.php?t=190072&highlight=
pkk888: Bump your old topic(reply to it) if noone answers instead of making a new topic.
Newbie codec question
By fotoruss in forum Video ConversionReplies: 7Last Post: 15th Sep 2010, 21:47 -
Newbie with a question on using Avidemux
By The Monarch in forum Newbie / General discussionsReplies: 6Last Post: 28th Sep 2009, 22:25 -
Newbie Divx question
By Contact in forum Newbie / General discussionsReplies: 13Last Post: 13th Apr 2009, 10:57 -
Newbie question about cd music
By justalice in forum AudioReplies: 4Last Post: 7th Apr 2008, 19:08 -
Newbie Networking question
By karl333 in forum ComputerReplies: 1Last Post: 5th Mar 2008, 12:23
