is there any way other than vstrip or ac3dec to decode audio from .vob files? i tried both programs and got error messages. i need a third option.
i like dvd2avi. just save as "project". you'll get a .wav file & a .d2v file.. its great
Make sure you choose the track you want under the audio tab. Don't want to get french or the directors com (I assume).
Graphedit, complicated but works wonders, guide's at digital digest or doom9.org
Uncheck the 48kh -> 44kh in DVD2AVI and it runs 20-30 mins for WAV extraction Vs. 1.5 - 2 hours! (AMD Ath Tbird 800)
DVD2AVI is still the best, and hard to beat! Not to mention, TMPGEnc reads the file "nativly" (with plug in).
<hr>
Well vested in the following: Pinnical DC-10+, TMPGEnc, AVI_IO, VirtualDub, Flask, BBMpeg, SmartRipper, DVD2AVI
<hr> -
If you just want the audio decoded to a wav file, you can also use FlaskMPEG. The benefit here is that you get to choose the audio stream (in terms of language rather than stream header) and you get to preview the audio before saving it.
Make sure you use V0.6 for this.
Regards.
Michael Tam
w: Morsels of Evidence
How to extract audio from .vob files
By webadm in forum Newbie / General discussionsReplies: 4Last Post: 16th Jan 2012, 21:28 -
Mp4 or 3gpp Files merge/joining and decoding parser
By fidogenial in forum Video ConversionReplies: 0Last Post: 8th Dec 2011, 14:02 -
Simple question about group files decoding
By SteveDM in forum ffmpegX general discussionReplies: 3Last Post: 25th Aug 2010, 05:58 -
Save Rendering Time--Change VOB to MPG--Set Audio VOB & MPG2 video files
By jake61 in forum Newbie / General discussionsReplies: 4Last Post: 5th May 2010, 15:12 -
programm for joining mpeg2 files without decoding and artifacts
By mb508 in forum EditingReplies: 1Last Post: 7th Aug 2007, 06:51
