I asked this question last night.
I burnt a svcd successfully but i found that my dvd does not support svcd.
Am I cooked? it does support vcd, but I need the svcd qulity.
thank you
yes you pretty much are cooked, the last thing i could recommend you do is encode in MPEG-1 format at 480x480. this way your player would recognise it as a VCD, but it would have SVCD quality because of the higher Res. this is all i can recommend. its a long shot, try it, but im not sure if it will work, because there is no correct aspect ratio for Mpeg-1 480x480 that shows on TV. try it anyway, it might just work
Wait a minute. Try this before you're going to reencode. Demultiplex the MPEG-2 file with TMPG.
Multiplex with TMPG as Video-CD(non-standard).
Author and burn as VCD.
Help with svcd 2 dvd
By tastybaker in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 11th Aug 2010, 09:30 -
Svcd 2 dvd
By GeordieDave in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 8th Feb 2010, 10:05 -
svcd will not launch.
By hawkwind in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 17th Jan 2009, 18:09 -
Procoder SVCD
By kippard in forum Authoring (VCD/SVCD)Replies: 7Last Post: 17th Dec 2008, 10:51 -
Help with PAL SVCD to NTSC SVCD
By silentmonolith in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2007, 06:18
