Ok here is what I want to be able to do, I hope this does not violate the no conversions rule here because my post is really about authoring software NOT about converting but I need to explain my situation first. I have a collection of Anime in OGM format that I intend to burn to DVD, these inlcude a video stream, multiple audeo streams and subtitle streams. I am confident I can demux these and rencode them to compliant DVD formats for the appropreat video/audio/subtitle streams, eg [*.m2v,*.(mp2,mpa,ac2,wav,etc...),*.sup]. Since these Anime episodes are only 30 mins long I would like to be able to fit more than one of them on a DVD and create a menu system to access each episode However I want to keep the multiple audio streams AND the subtitle stream. If I were only dealing with putting 1 episode per DVD then I wouldn't need to worry about having a menu and I could easily use IFOEdit to author the DVD. However the combination of menus and subtitles and multiple audio streams seem to narrow my options of software packages substantially since I understand that many authoring tools do not support the addition of subtitles. If possible I would very much like to use all freeware tools, I know this can greatly complicate things but I don't mind at all using multiple tools to get the job done. For example I have thought of doing it this way: Use IFOedit to create each 30min eps essentailly as a separate DVD because IFOEdit can handle the multiple audio streams and the subtitles, then use some kind of freeware program(s) to combine these DVDs into one larger DVD with a menu. If this or something like it is not possible then could anyone reccomed what they think would be the best "all-in-one" Authoring tool to fit these needs, again it must be able to handle multiple audio streams as well as subtitles and menu creation. Thanks!!!![]()
Looks like you need to jump up to something like Sonic's Reel DVD of course at $700.00 US, it might be better to give up on subtitles.
You could head over to the DVD-Lab forum and ask the experts there...
www.mmbforums.com--
Will -
Thanks for the suggestion! I'll look into doing this later when I get my burner, hopefully christmasOriginally Posted by andkiich
. If it works out I might even post a guide.
Authoring oversized DVD, then shrink to fit on a disc?
By adamberkey in forum Authoring (DVD)Replies: 1Last Post: 28th Apr 2012, 00:39 -
DVD Authoring Software
By Toxic1 in forum Authoring (DVD)Replies: 5Last Post: 21st Feb 2010, 03:39 -
Combining Srt files into one for the purpose of authoring a DVD
By isobel in forum Newbie / General discussionsReplies: 0Last Post: 25th Jan 2010, 07:48 -
Video Capture setup fit for dual purpose? could do with some advice.
By brek in forum Newbie / General discussionsReplies: 1Last Post: 14th Jan 2008, 05:25 -
Best DVD authoring software?
By skybadger in forum Authoring (DVD)Replies: 8Last Post: 16th Aug 2007, 06:11
