I can play both VCD AND SVCD... i need help.. which i know SVCD is better quality.. which is better though PAL NTSC OR NTSC FILM.. the reason why im asking it seems SVCD movies have to be put on more than one cd.. because of the space.so i was wonder that way i could put the best quality on a VCD on ONE CD. easy question im just new at this.. thanks..![]()
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
I dont mean to offend you but i will help you once you straighten out that second last sentence, it doesnt seem to be in english.
<font size=-1>[ This Message was edited by: Yeshi on 2001-10-12 01:57:02 ]</font> -
NTSC is the video stardard in the US, Canada and Japan.
Pal is the standard in Europe.
All PAL sources are 25fps.
NTSC TV is 29.97fps, however, movies are shot at 23.976fps. In order to play a 23.976fps source on a 29.97fps TV you have to convert the film to that format. This is done by a process known as telecine (aka 3:2 pulldown).
So use the template based on where you live and your source material.
The quaility of VCD (MPEG1) and SVCD (MPEG2) is due to the resolution and bitrates used: VCD 352x240 @ 1150kbit/s & SVCD 480x480 @ 2520kbit/s. At the SAME resolution and bitrate MPEG1 and MPEG2 look the same, the advantage of MPEG2 is the it supports: multiple audio tracks, multiple angles, subtitles, interlacing, etc. etc. -
I can play both VCD AND SVCD... i need help.. which i know SVCD is better quality.. which is better though PAL NTSC OR NTSC FILM.. the reason why im asking it seems SVCD movies have to be put on more than one cd.. because of the space.so i was wonder "which format to use" that way i could put the best quality on a VCD on ONE CD. easy question im just new at this.. thanks..
oh and YESHI tell me if this english is good enough for you.. i just needed help not a smart as$. i type really fast and it was pretty late when i posted my question.. so please dont insult me.. thank you VEGITA for your HELP!! thats what i wanted to know.. and just curious, you like DRAGONBALL?!? i do..
Using NTSC (16:9) and PAL (4:3) sources to restore a film...
By takearushfan in forum RestorationReplies: 61Last Post: 3rd Mar 2012, 16:13 -
NTSC/PAL but exact film length: How so?
By Anonymous5394 in forum Newbie / General discussionsReplies: 2Last Post: 5th Mar 2010, 12:42 -
NTSC video with a film-like/PAL to NTSC conversion type of look that shouldn't
By Bix in forum RestorationReplies: 34Last Post: 8th Feb 2010, 16:17 -
PAL VCD -> NTSC Video for NTSC DVD Authoring!!
By Mickey79 in forum Video ConversionReplies: 5Last Post: 12th Aug 2008, 12:30 -
FPS NTSC & PAL Film/Digital
By flamingo in forum Newbie / General discussionsReplies: 5Last Post: 13th Nov 2007, 14:21
