Hi!
Im looking for which is best and easy way to fit the HD-files from DVD-9 to two DVD-r without any compress and with all Menus,extras.... not only for the first DVDr, but also for secon DVDr, because its only 8,5GB-files!?
I have seen here some tips and comments about it, but unfortunately dont
found any of useful for me!
Skeeper
are you looking for menu/extra's on both DVD's and splitting a movie?
it may be 8.5GB but lets say the menu/extras are 2GB and the movie 6GB
so if you split the movie which is 3GB on each DVDR and then add the 2GB menu/extras it will be 5GB
so unless you can split and fit then you will have to compress something unless you can remove audio/subs to make it fit without compression
there are a few methods and tools that will allow you to split the DVD and keep exactly the content you want on both DVD's
I need an EASY program to edit things out of .flv files
By J Tinsby in forum Video ConversionReplies: 6Last Post: 28th Jun 2011, 03:07 -
Is there a free and easy to use editor for FLV files?
By MJ in forum EditingReplies: 1Last Post: 1st Apr 2011, 01:10 -
Easy way to join 2+ AVI files
By AppzBeWarez in forum EditingReplies: 2Last Post: 7th May 2009, 23:48 -
Easy for someone...why no video with converted youtube files?
By lordstafford69 in forum Newbie / General discussionsReplies: 3Last Post: 8th Jun 2007, 13:00 -
Easy way to convert DVD to mp4 files on a PC?
By gwoiler in forum DVD RippingReplies: 4Last Post: 31st May 2007, 14:53
