Would someone please advice how i go about copying my AVI movies from my hard disk to CD.
I have Nero 5.
Would appreciate any help so that i can free up some of my hard disk.
Many thanks.
Results 1 to 16 of 16
Will this CD then work in an external DVD player?
Can you burn other types of movies as data CD's like MPG files? -
If its in divx or xvid form then a few players have that capability.Originally Posted by Golfing
But 99% don't.
Yes you can. But once again very few DVD players have the capability to play them as raw mpeg files. You could convert them to VCD or SVCD then the compatibilty increases. They will play back on your pc tho.Originally Posted by Golfing
Fozzee -
It won't play on standalone players. It will only play on your computer.Originally Posted by Golfing
If you AVI is less than 20 minutes then you can use NERO to convert to MPEG1 and burn at the same time. When burnt as mpeg1, it can be played on most DVD players.Sam Ontario -
You have two choices for putting your avi files on CD - VCD or SVCD. Use Tmpgenc to encode your avi to either format, VCD is compatible with more standalone players than SVCD, but SVCD has better quality.
Mpeg files should already be in (S)VCD format and ready to burn.
Here is a good guide to get you started
https://www.videohelp.com/tmpgenc.htmJust shut up and listen dumbass -
I am sorry you are WRONG. There are some players capable of divx (avi) playback . Like I said 99% are not.Originally Posted by Sam Ontario
Here is an example of one................
http://www.877camcorder.com/dp450.html
There are others out there too for as little as £90 (UK)
Fozzee -
YeapOriginally Posted by Golfing
Nope... you select either Video CD (VCD) or Super Video CD (SVCD), depending on which of those two formats you said TMPGenc to convert your original video to.If so do i select data CD?
If you used TMPGenc to make a VCD compliant video file then you also select VCD in Nero in order to burn it. (same logic for SVCDs too).
Regards... -
Do you mean DIVX=AVI? Forget about DIVX! Here it is avi!Originally Posted by FozzeeSam Ontario
DivX=one flavor of AVI, that some DVD players can (/claims to) play.
@Golfing: I suggest you read some of the AVI to (S)VCD guides under Convert left.
/Mats -
Have you done so? What part of which guide caused you trouble?@Golfing: I suggest you read some of the AVI to (S)VCD guides under Convert left.
/Mats -
I have done the conversion successfully. It is the burning i am struggling with. I have used Nero to write this conversion to CD but then it wont even play the film on my pc. If you look on the CD there is 5 folders of info. No movie is there???Originally Posted by mats.hogberg
VCD isn't (mainly) supposed to be playd on the computer, but rather on a stand alone DVD player. To play it on your coputer, you can do so with a software DVD player, like PowerDVD.
Have you tried looking inside MPEGAV folder? There ought to be an AVSEQnn.DAY file in there.
/Mats -
/Mats[/quote]
Cheers mate when i go into that folder and open the file with Divx player it works.
Next step to try the movie on my DVDF player....... i will let u know.
How to copy Philips 3590H hard disk files to a computer
By themastan in forum DVD & Blu-ray RecordersReplies: 0Last Post: 15th Sep 2010, 07:15 -
Backing up DVD/Blu-ray to disk, watching movies directly from disk to TV.
By mb312 in forum Newbie / General discussionsReplies: 0Last Post: 11th Feb 2010, 16:35 -
How do i copy dvds onto hard drive and what is best software to copy sav
By bfishwick in forum Newbie / General discussionsReplies: 1Last Post: 13th Feb 2009, 18:29 -
Burning iso image from Hard disk to hard disk?
By When in forum Newbie / General discussionsReplies: 1Last Post: 12th Jun 2008, 23:27 -
hard disc 1 died, hard disk 2 won't boot, halp!
By Yoroshiku in forum ComputerReplies: 6Last Post: 30th Oct 2007, 14:48
