  1. i don't know what going on with dvd burn. after i burn dvd by using nero5. then watch it on dvd player. watch half way the film jump and halt. any one know what wrong ??? i used princo disk .
    canada
    Princo-thats your problem,try some better brand of blanks cause it sounds like a media issue.
  3. Originally Posted by thozon
    Try using Datawrite DVD/R media they seem to be one of the most compatible with most DVD players. I use the yellow label ones ,funnily enough they are made by Princo. I have had no problems with these on my Pioneer 106D
    Failing that you could try using DVDXcopy Express to varify if it is the software.
    Discs can be bought from here quite cheaply
    http://www.blankdiscshop.co.uk/acatalog/FOR_DVD_R_RW_CLICK_HERE.html
