  1. Having problems converting DV files created by ADCV-100 with ScenalyzerLive to MPEG-2 (NTSC) using TMPGEnc. Problem is that playback seems jerky during movement. Only thing that I’ve found that smoothes playback is to “Inverse Telecine” to 24fps.
    TMPGEnc settings used:
    From project wizard selected DVD NTSC
    Options changed after that
    Tried both CBR 8000 and VBR
    DC component precision: 10
    Motion search: Highest quality
    Video arrange method: Full screen (Keep aspect ratio)
    My newbie questions:
    Will changing the fps to 24 cause any problems with a standalone DVD player?
    Am I missing a setting in TMPGEnc that would allow smooth playback at 29.97 fps?
    System
    1800xp KR7A-R133
    4 60 Maxtor in raid 0
    9700pro ATI
    ADCV-100
    Hercules GTXP
    Canopus Codec
  2. Member Innershield's Avatar
    Jul 2001
    Akron, Ohio
    Try changing the field order under advanced in tmpg.
  3. Never mind
    I should have tried it in a standalone before posting here. 29.97 fps looks fine.
    Just can’t understand why it doesn’t look right with WinDVD.
