Everytime I burn an AVI to a VCD it has to convert the file to an MPEG first (obviously), but lately it seems to lock up my computer shortly into the conversion process. This happens regardless of the program I use to convert the file, and regardless of the file I am converting. It used to work but now it doesn't, and I'm at my wits end! Please help.
Results 1 to 14 of 14
Video encoding is very CPU intensive, if the problem is happening with several different program then I suspect a hardware issue. Bad CPU, ram, motherboard, power supply etc.
"Art is making something out of nothing and selling it." - Frank Zappa -
Originally Posted by Astronaut Down"Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey
Yeah, I've tried TMPGEnc, and the same thing happens, usually 2 to 5 minutes into the conversion. I've closed everything I know of that's running in the background, so it's just windows tasks that I don't want to mess with, no actual applications or anything. But it still happens. Maybe it is a hardware issue. I think I'm going to upgrade my ram anyway, hopefully that fixes it.
Thanks,
Joe -
Does this happen with all files or only certain ones ?
The decoder may have changed while you weren't looking.
See if Virtual dub will open and play it.
If it will, you can frameserve it to TMPGenc. -
who said anything about decoder changing, ive had new codecs that ive downloaded, but even wityhout using them they have interfered. quit acting like youre the video god
If I have bad codecs that are messing up my computer, how can I find out which ones and get rid of them? And yes, it happens with any and every file I try to convert. I don't remember downloading any new codecs, but it's been doing this for a little while, so that could be it ... is there a program that can scan my system for codecs and tell me which ones might be causing problems?
Ricky , I wish you would explain what you think I've done to piss you
off. I said just about the same thing you did. Something has changed
in the original posters configuration.
even wityhout using them they have interfered -
yes they can interferwe, some codec packs have s[pyware or are bundled with other nasty thigs that can interfere without you even knowing it
I have been trying to convert AVi to MPEG for some time now....WhenI use TMPGenc it always makes the outcome file so much larger...I was using DVD2SVCD and that was working great converting to a size not much larger than the original...but now I get an error can not find scenarist file. Does anyone know why this would happen..
Razz
Please Help with converting AC3 in an AVI to an AVI with MPEG-1/MPEG-2
By twin1701 in forum Newbie / General discussionsReplies: 4Last Post: 13th Jul 2010, 14:11 -
new Virtualdub MPEG - still a colorspace problem with MPEG-&
By sanlyn in forum EditingReplies: 6Last Post: 10th Aug 2009, 22:18 -
How to convert an MPEG file to DV-AVI Type 2 using MPEG Streamclip
By MAdNEZ in forum Newbie / General discussionsReplies: 15Last Post: 4th Aug 2009, 07:30 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 07:36 -
DGIndexed MPEG or AVI wrapped MPEG best for AVISynth?
By flywitness in forum EditingReplies: 1Last Post: 12th Sep 2008, 09:08
