I download avi files.
I convert them to mpg using tmpge
I burn them using Nero,Roxio Cd creator and I try to play them on my dvd but nothing
I tried to fix the mpg using Ifilmedit everything was ok but I still can't play them on my dvd
I'm sure my dvd support Video cd's.
What am I doing wrong?
please help
I waste like almost 20 cd's
please help
thanks
instead of wasting CD's buy one CD-RW. i used to ALWAYS test on CD-RW when iw asnt sure if is was doing things right. Make sure your stream type is correct, that could be it.
Is any file I can use to check if the avi file I have is damaged?>
or is any other file to use after encording to see if the mpeg file is good for VideoCd?
thanks
