I dont know if this is thew right forum for this but i want to capture the clone wars toon from the cartoonnetwork website they are in streaming format when i try to save it from the window it saves it as a .smil format..
I have tried to open that in quicktime with no luck can someone help?
I would love to have a vcd of the videos they have one just the toon itself the other with commentary
If you can help email me or post here thank you!
I assume this is ok since there is no copy protection and the files can be freely had from the 'owner'.
So here's some info:
The hi res QT version can be grabed over http. Here is an example url. (right click and save as)
http://progressive1.stream.aol.com/turner/gl/cartoon_net/starwars/chapter1/320_hi_dl.mov
You can use Blink/Smacker to convert the video. I'm not sure you can convert the audio. A quick time expert maybe could help. :P
To get the real media versions you need something that talks rtsp protocol. HiDownload is a (30-day trial) program that does.
Here is an example url for a real file (right click probably won't work here)
rtsp://demand1.stream.aol.com/turner/gl/cartoon_net/clonewars/chapter2/st_video.rm
You could use the real audio on the qt video. I believe there are guides for all of the conversion stuff.......
Have Fun !! -
thanks for the reply.. so i guess my question is how did you find the url.. because when i did a view source at the cartoon network all i could find was the smil file link.. thank you
To get the URLs
Right click on the url's I gave and check the properties. All the other mov/rm files are a simple variation of the 1st. 'chapter1', 'chapter2', ...
OR
If you just want to know for future fun, open the smil file in notepad.
Edit BTW, I did not grab all of the files. I'm not planning on doing what you want to do. I just thought it was interesting so I took a look. Kinda wished I captured the broadcasts when they were on tv. Too bad they only show them in small little bites. -
A bit off topic but they ran all ten last night { 11/21/03 }.
Have read of plans to release them on DVD. Abou the other 10 of the total twenty have no idea when they will be released. Just a vauge 2004 listing. -
Trevlac,
They showed all 10 at once on friday. They're supposed to do it again soon.
video567,
You can convert with TMPGEnc. There is a quicktime vfapi in the Tools section (I think).
Also, try these URLs (right click and Save-As) Make sure that "Save movies in disk cache" is checked in the QuickTime Plug-in Setting.
http://www.cartoonnetwork.com/clonewars/video/meta/standard/qt/chapter1_320_hi.mov
http://www.cartoonnetwork.com/clonewars/video/meta/standard/qt/chapter2_320_hi.mov
http://www.cartoonnetwork.com/clonewars/video/meta/standard/qt/chapter3_320_hi.mov
http://www.cartoonnetwork.com/clonewars/video/meta/standard/qt/chapter4_320_hi.mov
http://www.cartoonnetwork.com/clonewars/video/meta/standard/qt/chapter5_320_hi.mov
http://www.cartoonnetwork.com/clonewars/video/meta/standard/qt/chapter6_320_hi.mov
http://www.cartoonnetwork.com/clonewars/video/meta/standard/qt/chapter7_320_hi.mov
http://www.cartoonnetwork.com/clonewars/video/meta/standard/qt/chapter8_320_hi.mov
http://www.cartoonnetwork.com/clonewars/video/meta/standard/qt/chapter9_320_hi.mov
http://www.cartoonnetwork.com/clonewars/video/meta/standard/qt/chapter10_320_hi.mov -
thanks for the info on the smil file i didnt know that.. i wish i could have catched the ten eps lastnight.. it would have made it so much easier for me i could have made my vcd by now.. i thank you for your time and information. thankyou so much
Intermitent failure when streaming from MS Media Streaming Services
By OshiDaro in forum Video Streaming DownloadingReplies: 0Last Post: 8th Dec 2010, 07:10 -
Clone Wars Blu-ray Problem
By Tronathon in forum Blu-ray RippingReplies: 7Last Post: 17th Apr 2010, 00:13 -
Digital Copy DVD Video that came with my blu-ray disc of clone wars
By logannsan in forum DVD RippingReplies: 9Last Post: 16th Nov 2008, 11:58 -
Anyone seen Clone Wars yet?
By yoda313 in forum Off topicReplies: 19Last Post: 12th Oct 2008, 08:10 -
capturing streaming video
By robotica71 in forum Video Streaming DownloadingReplies: 13Last Post: 14th Mar 2008, 10:18
