  1. OK, i done a test encode on a extra feature from a dvd by resizing it down to 352x576, ive authored it using ifoedit author.So now i have the vobs ,ive updated vts sectors.
    What i would like to know is how can i burn these files to a cdr so my player will reconise the disc.The files are only 310mb.Ive tryed burning the files the same way as i would a dvdr but i get a wrong disc format error come up on my player.I also tryed that minidvd thing in nero(dont have much of a idea of what minidvd is, i can only guess), i get the same error.
    So how can i burn these files so they work ???
    ps, im not wasting a dvdr for 310mb and my player does'nt read dvd-rw as ive already tryed.
    Big 3 User.....
    PAL User.......
    Apr 2002
    The State of Frustration
    Some players do not play miniDVDs. But I do know if you put a blank
    CD-R disk in your burner, run Video Studio, and tell it to make a DVD with the CD-R, it will make one. Trouble is, it does not like VOBs.
    Hello.
  3. Human j1d10t's Avatar
    Feb 2003
    California, USA
    Since you already got the authored VOB, IFO, and BUP files, could you burn them with a burning program (such as Nero), with the CD-ROM ISO setting? And put the VOB, IFO and BUP files in a VIDEO_TS folder, and add a blank AUDIO_TS folder. Just wondering, since DVDs are burnt in ISO...
    "Don't try to be a great man. Just be a man, and let history make its own judgment."
    Zefram Cochrane
    2073
  4. Member wulf109's Avatar
    Jul 2002
    Nero 5.5 burn as UDF/ISO data,make a VIDEO_TS directory for the files.
    Nero 6 has a miniDVD template under CDR and includes the VIDEO_TS directory. I do miniDVD this way but many DVD players donot support miniDVD.
  5. I dont know any player playing cd-r with dvd struktur. Even if it is an UDF cd. I think DVD player first look with typ of media is in the player (CD or DVD). If it is a CD the player searchs for supported CD strukturs like audioCD, mp3CD,.... and ISO or UDF or UDF/ISO bright VIDEO_TS-struktur isnt supported for CD.
    If you only need to burn for testing burn to DVDRW (UDF 1.02)
    If I didnt understand your problem its my bad english!!!
  6. I think that, if bit rate is around 3Mbps, your player would play the miniDVD cd-r. By the way have you had a look at DVD players compatibility list on this site?
