Hi,
Well I'm capturing dv and want to convert the capture to xvcd. I'm using video studio and there doesn't seem to be an easy way to convert the 4 gig segements from 98se. I guess I'll upgrade to windows 2000, but first I want to make sure afterfware I can just dump the 20 gig capture directly into TMPGEnc and convert to xvcd?
Thanks, Jerry
TMPGEnc has a "add" feature under MPG tools. First encode each section under the VCD or SVCD template of your choice making a MPG file for each 4GB source file. When done, go to the MPG tools section and just "add" them creating a joined MPG file. Works fine. I do it all the time.
Should be no problem. I recently dumped a 1 hr. 45 min. video to DV using my camcorder as pass through in one go creating one huge file on my hard disk. I was able to convert it to VCD using tmpgenc without any problems.
Windows XP with NTFS partitioning may be a better option (I am currently thinking about it)
There seems to be, however, a number of issues to clarify first, such as will all the capture, encoding, authoring & burning software cope with NTFS partitioning. Then, what about all the other software I have...
Nero 5.5.5 is their official XP version but I haven't seen any specific reference to being OK with NTFS. But seeing I have given up on Nero for the time being this does not matter to me (use VCDImagerEasy+Cdrdao).....
At this stage, unless you are capturing & preparing (s)vcd's on a very regular basis (daily, professionally) I think it better to stick with the 4GB limit and let TMPGEnc encode to separate mpg files, then join them together. It works well. - If it aint broke, why fix it... Also, why not let the bugs get ironed out with XP.
mdez -
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
Nero works fine on my system with Windows XP with the NTFS. =) -
There is one more thing to consider, I don't know if TMPGenc encodes directly from a Type 1 DV file, if it does then there is no problem. But if you have to concert that file to Main Actor DV, or MJPEG, or uncompressed you still have a 5 gb limit under W2K, this is created by the AVI file.
Alfonso
Why can't I convert an AVI file over 4 gig?
By danzautomatic in forum ffmpegX general discussionReplies: 3Last Post: 23rd Nov 2010, 08:59 -
Losing audio when i convert a 2 gig mp4 bluray to dvd with nero vision
By pkath123 in forum Video ConversionReplies: 0Last Post: 7th Nov 2010, 16:48 -
25 gig BluRay to BD-R?
By Mark_Venture in forum Blu-ray RippingReplies: 3Last Post: 6th Sep 2009, 07:56 -
1 GIG video
By moonshadow in forum Video ConversionReplies: 13Last Post: 23rd May 2009, 00:21 -
How many 4.7 Gig DVDs may fit into 500 gig HDD?
By Bronx in forum ComputerReplies: 11Last Post: 24th Apr 2008, 09:40
