I have been converting quite a few of my tapes to DVD over the past month.
Initially, I was using Vegas 4.0, and converting to Mpeg2 using it's built-in Mainconcept Encoder. The results were pretty good.
The last couple of times, I decided to use Tmpgenc Plus to convert to Mpeg2. I was blown away by the quality. The results were much more pleasing than with the Mainconcept Encoder. even using one-pass constant bitrate.
The Mainconcept seemed to produce some artifacts (blockiness).
The Tmpgenc Plus encoder prodeced ALOT FEWER artifacts, and blockiness was almost non-existant, even at bitrates as low as 4MB/s.
This has just been my observation. Needless to say, I will continue to use Tmpgenc for DVD conversion.
Question... Is there an easy way to frameserver Vegas 4.0 to Tmpgenc Plus?
Sound quality of Tmpgenc: Is it that bad?
By Banleno007 in forum Video ConversionReplies: 3Last Post: 15th Feb 2012, 21:10 -
Ripping DVDs as MPEGs using TMPGenc --- loss in quality?
By DieselsDen in forum DVD RippingReplies: 5Last Post: 21st Sep 2010, 12:09 -
TMPGEnc advanced settings for best quality results
By tdavid232 in forum Video ConversionReplies: 1Last Post: 15th May 2008, 18:02 -
New to TMPGEnc DVD Author 3 - Two Questions on Video Quality
By heyjjjaded in forum Authoring (DVD)Replies: 0Last Post: 16th Aug 2007, 12:15 -
What are the current encoders comparable to tmpgenc in quality?
By inuyasha in forum Video ConversionReplies: 24Last Post: 26th Jun 2007, 05:43
