Why does this bloody program hang at resampling the audio to 48000hz. Please help as I'm arsed off with it now.
JamangieGuest
post your log file & we may have a chance of helping you.
JamangieGuest
Here you go, Hope it helps.
Starting SVCD2DVD DEMO: v1.5.1416.29638
Begin time: 19:54:25
******** Ripping SVCD images to get mpegs
Analysing File: Z:\Newsgroup Downloads\alt.binaries.dvd2svcd\Xmas vacation cd1\Xmas vacation cd1_D.mpg
++ WARN: mpeg stream will be padded on the fly -- hope that's ok for you!
++ WARN: mpeg user scan data: one or more BCD fields out of range for 'next_I_offset ': [00:06.0e]
++ WARN: packet length beyond buffer (pos = 20 + size = 2304 > buflen = 420) -- stream may be truncated or packet length > 2324 bytes!
++ WARN: bad packet at packet #452 (stream byte offset 1048156) -- remaining 420 bytes of stream will be ignored
++ WARN: autopadding requires to insert additional 2292 zero bytes into MPEG stream (due to 1 unaligned packets of 452 total)
-->Processing 1 mpeg files.
############### New MPEG File ###############
Type: SVCD
Horizontal Res: 480
Standard: NTSC
Audio SampleRate: 44100
******** Preparing asset
Truncating Asset.
Truncating Asset - done.
Now processing Xmas vacation cd1_D_D.mpg 1/2 ...
Now processing C:\Program Files\Badgersoft\SVCD2DVD DEMO #2\NTSCSVCD.mpg 2/2 ...
******** Demultipexing original mpg file
bbDMUX - version 1.9, by Brent Beyeler (beyeler@home.com)
speed increases by, Apachez and Christian Vogelgsang
Saving stream 0xE0 into file Z:\Newsgroup Downloads\alt.binaries.dvd2svcd\Xmas vacation cd1\Xmas vacation cd1_D_DVD.mpv...
File Z:\Newsgroup Downloads\alt.binaries.dvd2svcd\Xmas vacation cd1\Xmas vacation cd1_D.mpg is an MPEG-2 Program Stream
pack header field flag value not allowed in program streams
Saving stream 0xC0 into file Z:\Newsgroup Downloads\alt.binaries.dvd2svcd\Xmas vacation cd1\Xmas vacation cd1_D-0.mp2...
******** Applying SDE headers
Badgersoft 2003 - SDE Patcher (SVCD) v1.02 (bugs/info: sde@<a class="contentlink" href="https://www.videohelp.com/tools?tool=157#comments" targ...dvdmpg</a>.com)
Standard: NTSC
Working:
--- Patched 4161 headers
******** Resampling audio from 44.1 KHz to 48 KHz
System.Exception: ProcessRunner::Run(): no such Program: C:\Program Files\Badgersoft\SVCD2DVD DEMO #2\madplay.exe
at a.a(String A_0, String A_1, String A_2, h A_3, Boolean A_4)
at j.d(g A_0)
at j.g()
at j.d(g A_0)
at j.g() -
Ah - thanks for showing this. I see you are trying to encode with AC-3. I didn't include the relevent programs for that. I have included them now. Therefore if you re-download the demo & reinstall you should be okay.
Please let us know.
I apologise again.
CBSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
AutoMKV Stuck While Encoding Audio
By bobandrews in forum Video ConversionReplies: 2Last Post: 15th Feb 2011, 22:43 -
DVD Stuck
By tvlreject in forum DVD & Blu-ray WritersReplies: 15Last Post: 2nd Dec 2007, 21:39 -
stuck with only one HD channel
By rallynavvie in forum Media Center PC / MediaCentersReplies: 4Last Post: 1st Aug 2007, 14:32
