Can TMPGEnc handle an AVI file that's larger than 2 gb?
The reason I ask is at work, we have a Decreet Edit* workstation capable of capturing from a Digi Beta source at uncompressed quality.
Now, at the level of quality, anything captured that's over a couple of minutes is over 2 gb. Those files, seemingly, will not convert in TMPGEnc. I get an "ACM" error, or some other error that states the video is of uncompatible format.
Now, using the same system with the same capture settings, shorter videos -- say, commercial length -- convert in TMPGEnc.
Any thoughts?
Yes, I can confirm that TMPGEnc works with files larger than 2GB. I am using the NTFS (New Technology File System) that allows Windows to work with files larger than 4GB. My AVIs are usually ~6GB a piece when I capture from my cable.
That 'ACM Error' seems like an audio related error. Perhaps you don't have the proper codec installed?
mp3 in acm wrapper?
By DarrellS in forum AudioReplies: 5Last Post: 11th Oct 2010, 22:30 -
Vegas + LAME ACM = just a myth..?
By Gew in forum EditingReplies: 3Last Post: 24th Jul 2008, 03:48 -
Can't install Lame ACM
By suerpflysocal in forum Newbie / General discussionsReplies: 1Last Post: 7th Feb 2008, 09:16 -
Problem with AC3-ACM ???
By kehn in forum AudioReplies: 2Last Post: 27th Jul 2007, 00:05 -
AC-3 ACM Codec na RMVB = PROBLEM
By krain_l in forum Authoring (DVD)Replies: 1Last Post: 16th Jun 2007, 18:48
