Using the Component capture from the ATI TV 7.5 audio is there when capturing, but when I play back the .mp2 file I have no audio. I can't find any options for sound capture in the ATI TV settings, so I'm not sure where the audio went, or if it was ever captured.
Internal audio cable attached form ATI 8500DV to TAD in on SB Live.
Any ideas?
LordSmurf.com is under construction. I knew I should have printed that guide.![]()
Re-run the initialization wizard (setup->display_initialization wizard), and make sure the audio cable is properly connected.
Also, is there a reason why you're still using MMC 7.5 ? That version had many issues that were fixed in 7.6/7.7.
The best MMC versions are 7.7 and 8.1+ -
Do what Sulik said.
Yepo, I'm down for about a week. No e-mail, no site, no nothing.
But you'll like it when it fully comes up.Want my help? Ask here! (not via PM!)
I had similar issues / problems with my ATI Radeon AIW.
I now own a Canopus ADVC-100 and love it.
The problem you describe happened to me often. I thought at the time it was the ULEAD s/w that came bundled with the AIW.
I had to keep the Audio Out from the AIW connected to the AUX input of my sound card. It looks like you are doing something comparable.
I also found that I needed to go into the control panel's Sound set-up and under the Options pull down, select Preferences and then click on the Recording button. It varies a bit depending on your OS. But there are boxes to check for different sources. I don't remember which one I needed to select, but after experimenting I found that one worked and the sound was captured properly.
What was very frustrating is that often - maybe because I re-booted - who knows - the setting would default and my capture would be missing sound again. But like you said, the sound is perfectly audible out of the speakers - yet no capture.
With the ADVC-100, I haven't missed a beat or a frame!
Good Luck
Capture problems using ATI TV Wonder HD 750
By SKot in forum Capturing and VCRReplies: 9Last Post: 3rd Jan 2012, 16:34 -
Sound with ATI AIW 9800 Pro
By andrewjameshoward in forum Capturing and VCRReplies: 1Last Post: 8th Aug 2010, 07:02 -
need help with ati TV wonder 650 USB - no sound with virtualvcr
By deffy in forum Capturing and VCRReplies: 15Last Post: 6th Aug 2010, 04:16 -
How 2 Capture HD with ATI HDTV Wonder
By NautTboy in forum DVB / IPTVReplies: 41Last Post: 2nd Apr 2010, 13:38 -
ATI TV Wonder H.264 no sound
By euthyphro in forum AudioReplies: 1Last Post: 18th Jan 2008, 18:54
