Results 1 to 17 of 17
    Dec 2002
    tmpgnc always transfers the video and the audio into separate files, how do i make it create one file, the option to split the audio and video files is always checked and i cannot uncheck it!!! any ideas
    Oct 2002
    Huntsville, Ontario, Cana
    If you cannot click the "System (Video+Audio)" button, then I suggest you uninstall it and reinstall it.
    Will
  3. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    You should be able to select whichever button you like after loading one of the templates.
    Dec 2002
    ive read the "common problems" user guide on this but cant seem to work out how to load a template!!!! do i do this before i select an AVI file ?????????????
  5. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    Are you using the project wizard?
    If yes, then you need to select your input first, before your template. In the 5th window make sure to unselect "output video and audio as individual elemantery streams."
    If no, then you can select your input or "load" your template in any order.
  6. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    Originally Posted by efiste2
    ... the option to split the audio and video files is always checked and i cannot uncheck it!!!
    I just realized you're using the wizard. As suggested, if you can't uncheck it then try a re-install.
    Dec 2002
    i can load the template, if i dont use the "wizard" but the output file is MPEG, to questions..............
    1. what can i use to burn these files to a dvd so it plays on standalone dvd players
    2. the outputted mpeg file has a poor picture quality that consists of stripes across the screen??
    i have used WINDV to capture the DV from my advc 100 and the picture is great but when is been through tmpgen its poor??
    i would be gratefull for any advice.
  8. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    TMPGEnc is an mpeg encoder, it will output either an mpeg (video and audio combined) or M2V and MP2 (elementary video and audio mpeg streams). In order to burn to a DVD these files need to be "authored" first then burned, you can input either the mpeg or the individual streams into your authoring program. Click on the "Author" link over there <-<-<-.
    The lines you see are interlacing from your video capture and should disappear on playback on your TV.
    Dec 2002
    aaaaaaahhhhhhhhhh so i can import it into tmpgen author now cant I and take it from there, thanks for the advice guys, i appreciate it!!!
  10. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    You're on your way!
    Oct 2002
    1. To Author to DVD, you need an authoring program (makes sense right ) I have tried several, and now use DVD-Lab, give it a shot, it is free for 30 days and then only $80 to register. The output rivals Ulead and Sonic products at 8X the price.
    2. That depends on how you encoded it with TMPGEnc. If you are going to DVD, try the DVD template of the Half-D1 template. Some good templates can be had at www.kvcd.net
    If set correctly, the MPEG file created with TMPGEnc can be just as good as the input file.
    Will
    Dec 2002
    i have just used RNMAX 4.5 to burn the video TS file and the picutre stutters when there is movement, any thoughts, i authored the dvd using tmpgen author and the TS file doesnt stutter when watched on the PC so it must be the burning????? any hints
    Oct 2002
    wow, we need lots of information before we answer that....
    Are you in PAL or NTSC land?
    How many clips were used?
    Were they all the same video resolution?
    Was the audio all the same format and bitrate?
    Are you using a DVDR or RW?
    + or - media?
    Have you checked that your stand alone player can handle your media?
    Will
    Dec 2002
    thanks for staying with me on this...............
    yes its pal, with one clip (55mins) all the same reolution, with audio the same etc burned onto a DVD-r that plays well on both my standalone DVD players, as ive said its like a stutter/strobe effect any advice is really appreciated!!!
    Apr 2003
    Largo, FL
    If you cannot click the "System (Video+Audio)" button then click on 'Load', then double click on the 'Extra' folder and double-click on 'unlock'.
    Oct 2002
    I came across that effect once...
    I am in NTSC land, a friend in Britain ICQed me a DivX file, I converted it with TMPGEnc and the playback was the same.
    It turned out to have something to do with the Interlacing, because I re-encoded the original file and Deinterlaced it. The result played perfectly.
    Will
    Dec 2002
    whats the best way to de-interlace it then?
