Hello,
What is the best way to burn a DVD-R if I only have got the VTS_01_0.IFO and the vobfiles (VTS_01_1-4.VOB)? Total is less than 4gb. No reg. Code and No encryption. Smartripper was used to get the main movie.
Thanks for any help.
Results 1 to 11 of 11
No IFOedit is not needed. I use RecordNow Max to do all my burns.Originally Posted by manx30
OK so youve got all the vob,vts,and ifo files for the film yeh ? , SO make a new folder named with CAPS LOCK on eg all in capital letters "VIDEO_TS"
Load blank DVD into Burner/Writer
I use Nero 6
Open nero ,select "File" - "New Compilation"
In pop up box to the left at the top change to "dvd"
Now Select "DVD-Video" in left hand window
Select the "ISO" tab at the top of the pop up window
Select in the FILE/Directory name length area "ISO level 1(Max 0f 11=8+3 chars)
Select Character Set as ISO 9660 and leave all other settings unchecked
Click New on far top right
You are presented with a window with 4 frames
On the right - hand side select your VIDEO_TS folder that you dumped all your VTS files etc into
Double click on that folder to view contents
Single click on the first file and press CTRL and A and all the files will be highlighted
Hold left mouse button down over the first file and Drag all highlighted files over the RED VIDEO_TS folder on the left side panel
Depress mouse button and dump your files onto the RED VIDEO_TS folder
(MAKE SURE THAT YOU RELEASE THE MOUSE BUTTON WHEN THE MOUSE CURSER IS DIRECTLY OVER THE RED VIDEO_TS FOLDER
Finally click on the Burn Icon
Sit back and have a cup of tea whilst nero does the rest -
Update:
I coudn't use DVD Fab as it crashed so I took ifoedit instead.
I created new ifo's and put them in a new folder. I then moved the vob-files to that folder. I then pushed "GET VTS Sectors" in ifoedit.
Chedked the film in ifoedit DVD play. As it worked as I wanted it I burned it. IThe movie starts automaticly without menus and stuff. Works fine for me.
Thanks guys. -
LOL , youve got to laugh,the original message states
Some extras was taken away.
that Smartripper was used to rip the dvd files from the disc soooo
Because the extras werebt included eg trailers etc all your left with is the main movie yeh ?
So just read my other post
Voila -
You might be laughing buddy but you do not have a clue right?Originally Posted by tazwoh2002
Manx30 ripped the main movie only like this:
VTS_01_0.IFO
VTS_01_1.VOB
VTS_01_2.VOB
VTS_01_3.VOB
VTS_01_4.VOB
You cant just burn these onto a DVD-R!
The only way to do so is to create the missing navigation files with IFOEdit or DVDFab. (VIDEO_TS.BUP, VIDEO_TS.IFO, VTS_01.BUP)You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off.
Virtual Dub 1st & 2nd Pass Encoding
By OrchestraAndChoir in forum Video ConversionReplies: 10Last Post: 22nd Jul 2012, 08:20 -
Best Software to Edit VOR & IFO Files from Panasonic RAM Disk & Arc
By JDex in forum Newbie / General discussionsReplies: 16Last Post: 30th Sep 2009, 06:55 -
How do you make a DVD from only some VOB & IFO files?
By JoeBolden in forum DVD RippingReplies: 3Last Post: 12th Mar 2009, 01:12 -
ifo edit / Need help in editing DVD transport function & aspect ratio
By chazuke in forum Authoring (DVD)Replies: 1Last Post: 12th Oct 2008, 08:58 -
Panasonic DMR-E55-E55S or E55K?1st DVD recorder/1st time posting
By ToeTagged in forum DVD & Blu-ray RecordersReplies: 7Last Post: 19th Jan 2008, 15:33
