Hi,
I have a movie spread over two Xvid AVIs. What is the easiest way to convert these to a single file so I can MPEG it for DVD? It seems like TMPGenc wont let you merge AVIs so it it neccesary to convert both to MPEG and join them then?
Cheers
b0rked
Hi,
Thanks for the advice... I tried it but VideoStudio said it was unable to find the acdio codec. The Xvids have AC3 sound and I have the codec as the play fine in media player. Any ideas? -
Media Player often gets its codec from the Internet. If you will not manually install the codecs, I suggest you go ahead and convert your files to MPEG as you planned.
Hello. -
Hi,
I had to download and install the AC3 codec manually as WMP wouldn't dot it for me so i have a stand-alone AC3 codec on my machine...
VirtualDub/Xvid question: YV12 vs. XVID FourCC in the xvidvfw.dll driver???
By KneeRow in forum Video ConversionReplies: 14Last Post: 1st Aug 2010, 14:35 -
Does xvid cli (command line version of xvid) actually exist ?
By vhelp in forum ProgrammingReplies: 10Last Post: 29th Oct 2009, 15:18 -
help combining 2 xvid avis and 2 subtitles (srt) to 1 xvid avi
By hibbs in forum SubtitleReplies: 4Last Post: 14th Jun 2009, 20:05 -
How to encode an xvid file to another xvid and prevent video blocking?
By BlooderButcher in forum Video ConversionReplies: 5Last Post: 21st Nov 2008, 17:03 -
Weird I don't have XviD or DivX codec installed but I can see Xvid movies
By Talayero in forum Software PlayingReplies: 4Last Post: 5th Jun 2008, 12:47
