I'm having several problems with the latest FfmpegX. I installed the latest version and reinstalled all of the new binaries. Now all of my encodes fail. I have tried several files - all failed. I've been trying to convert avi files to VCD or SVCD. I am finding the latest version to be less capable than the previos one I was using (6g). Here is a post of my terminal window:
INFO: [yuvscaler] yuvscaler (version 1.7.0) is a general scaling utility for yuv frames
Fri Nov 21 19:13:51 CST 2003
INFO: [yuvscaler] (C) 2001-2002 Xavier Biquard <xbiquard@free.fr>
INFO: [yuvscaler] yuvscaler -h for help, or man yuvscaler
## Component Manager: attempting to find symbols in a component alias of type (regR/carP/x!bt)
++ WARN: [yuvscaler] Could not infer norm (PAL/SECAM or NTSC) from input data (frame size=352x240, frame rate=24000:1001 fps)!!
INFO: [yuvscaler] input: frame size: 352x240 pixels (126720 bytes)
INFO: [yuvscaler] input: frame rate: 24000/1001 fps (~23.976024)
INFO: [yuvscaler] input: interlace: none/progressive
INFO: [yuvscaler] input: sample aspect ratio: 1:1
INFO: [yuvscaler] from 352x240, take 352x240+0+0, NOT_INTERLACED/PROGRESSIVE
INFO: [yuvscaler] scale to 352x240, 352x240 being displayed, NOT_INTERLACED/PROGRESSIVE
INFO: [yuvscaler] Scaling uses the RESAMPLE algorithm,
INFO: [yuvscaler] without line switching
INFO: [yuvscaler] without time forwarding
INFO: [yuvscaler] Without luminance correction
INFO: [yuvscaler] Without chrominance correction
INFO: [yuvscaler] frame rate: 23.976 fps
INFO: [yuvscaler] Scaling ratio for width is 1 to 1
INFO: [yuvscaler] and is 1 to 1 for height
INFO: [yuvscaler] Specific downscaling routing number 4
INFO: [yuvscaler] output: frame size: 352x240 pixels (126720 bytes)
INFO: [yuvscaler] output: frame rate: 24000/1001 fps (~23.976024)
INFO: [yuvscaler] output: interlace: none/progressive
INFO: [yuvscaler] output: sample aspect ratio: 1:1
INFO: [mpeg2enc] VCD default options selected
INFO: [mpeg2enc] Selecting VCD output profile
INFO: [mpeg2enc] Assuming norm NTSC
INFO: [mpeg2enc] Encoding MPEG-1 video to /Users/randolph/Desktop/Video Proj/movie.m1v
INFO: [mpeg2enc] Horizontal size: 352 pel
INFO: [mpeg2enc] Vertical size: 240 pel
INFO: [mpeg2enc] Aspect ratio code: 12 = 1:1.1250 (4:3 NTSC for 720x480/352x240 images)
INFO: [mpeg2enc] Frame rate code: 1 = 24000.0/1001.0 (NTSC 3:2 pulldown converted FILM)
INFO: [mpeg2enc] Bitrate: 1151 KBit/s
INFO: [mpeg2enc] Field order for input: none/progressive
INFO: [mpeg2enc] New Sequence every 700 Mbytes
INFO: [mpeg2enc] Assuming non-video stream of 246 Kbps
INFO: [mpeg2enc] Search radius: 16
INFO: [mpeg2enc] GOP SIZE RANGE 9 TO 15
INFO: [mpeg2enc] Setting colour/gamma parameters to "NTSC"
INFO: [mpeg2enc] Progressive format frames = 1
INFO: [mpeg2enc] mpeg1 - setting intra_dc_precision = 0
INFO: [mpeg2enc] Using default unmodified quantization matrices
INFO: [mpeg2enc] Buffering 39 frames
INFO: [yuvscaler] End of stream!
INFO: [yuvscaler] Normal exit: end of stream with frame number 123569!
INFO: [mpeg2enc] Guesstimated final muxed size = 900590777
INFO: Opened WAV file, freq = 48000 Hz, channels = 2, bits = 16
INFO: format = 0x1, audio length = 0 bytes
INFO: slots/frame = 731
INFO: frac SpF=0.429, tot bitrate=224 kbps, s freq=44.1 kHz
INFO: Fractional number of slots, padding required
INFO: System is big endian
**ERROR:
Error reading wave data
AAHHHHHGGG!!!
What can I do to get this to work? It all use to flawlessly (well pretty much); but now I cant get anything to work. The above created a video file, and an empty audio file ( Zero KB). Please help.
Mr. Anderson
Results 1 to 13 of 13
Mr AndersonGuest
Post information about your input file (as shown by ffmpegX above the Open.. field).
Originally Posted by major
I just tried to encode again: here's my terminal window:
Sat Nov 22 17:38:11 CST 2003
INFO: [mpeg2enc] Encoding MPEG-1 video to /Users/randolph/Desktop/Video Proj/thomas.m1v
Not sure what else you need? The "open field," shows "/Users/randolph/Desktop/Video Proj/Thomas.avi.fixed.avi." Thanks for the help.
Mr. Anderson
INFO: [yuvscaler] input: sample aspect ratio: 1:1 "
That is all info on the input file. I did note the other post to disable Quicktime as the decoder. I'll try again and choose mencoder instead.
As an aside, I really miss 0.0.6g with it's ability to rip from a disc. But I do understand why you had to disable this feature.
Mr. Anderson
Originally Posted by Guest
Mr Anderson
Sun Nov 23 22:54:35 CST 2003
Input #0, avi, from '/Users/randolph/Desktop/Video Proj/Thomas.avi.fixed.avi':
Stream #0.0: Video: mpeg4, 432x320, 23.98 fps, 800 kb/s
Stream #0.1: Audio: mp3, 48000 Hz, stereo, 96 kb/s
Output #0, yuv4mpegpipe, to 'pipe:':
Stream #0.0: Video: rawvideo, yuv420p, 352x240, 29.97 fps, q=2-31, 200 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Press [q] to stop encoding
INFO: [yuvscaler] VCD output format requested in NTSC norm
INFO: [yuvscaler] input: frame rate: 2997/100 fps (~29.970000)
INFO: [yuvscaler] Scaling uses the BICUBIC algorithm,
INFO: [yuvscaler] frame rate: 29.970 fps
INFO: [yuvscaler] Specific downscaling routing number 1
INFO: [yuvscaler] output: frame rate: 2997/100 fps (~29.970000)
INFO: [mpeg2enc] Encoding MPEG-1 video to /Users/randolph/Desktop/Video Proj/ThomasVCD.m1v
INFO: [mpeg2enc] Aspect ratio code: 1 = 1:1 (square pixels)
INFO: [mpeg2enc] Frame rate code: 4 = 30000.0/1001.0 (NTSC VIDEO)
INFO: [mpeg2enc] Setting colour/gamma parameters to "unspecified"
INFO: [yuvscaler] Couldn't read FRAME header: bad header magic!
**ERROR: [yuvscaler] Couldn't read frame number 123571!
INFO: [mpeg2enc] Guesstimated final muxed size = 720484283
Output #0, mp2, to '/Users/randolph/Desktop/Video Proj/ThomasVCD.mp2':
Stream #0.0: Audio: mp2, 44100 Hz, stereo, 224 kb/s
Stream mapping:
Stream #0.1 -> #0.0
INFO: [mplex] mplex version 2.2.2 ($Date: 2003/05/13 20:27:15 $)
INFO: [mplex] File /Users/randolph/Desktop/Video Proj/ThomasVCD.m1v looks like an MPEG Video stream.
INFO: [mplex] File /Users/randolph/Desktop/Video Proj/ThomasVCD.mp2 looks like an MPEG Audio stream.
INFO: [mplex] Video stream 0: profile 1 selected - ignoring non-standard options!
INFO: [mplex] Found 1 audio streams and 1 video streams
INFO: [mplex] Selecting VCD output profile
INFO: [mplex] Multiplexing video program stream!
INFO: [mplex] Scanning for header info: Video stream e0 (/Users/randolph/Desktop/Video Proj/ThomasVCD.m1v)
INFO: [mplex] VIDEO STREAM: e0
INFO: [mplex] Frame width : 352
INFO: [mplex] Frame height : 240
INFO: [mplex] Aspect ratio : 1:1 (square pixels)
INFO: [mplex] Picture rate : 29.970 frames/sec
INFO: [mplex] Bit rate : 1152000 bits/sec
INFO: [mplex] Vbv buffer size : 40960 bytes
INFO: [mplex] CSPF : 1
INFO: [mplex] Scanning for header info: Audio stream c0 (/Users/randolph/Desktop/Video Proj/ThomasVCD.mp2)
INFO: [mplex] MPEG AUDIO STREAM: c0
INFO: [mplex] Audio version : 1.0
INFO: [mplex] Layer : 2
INFO: [mplex] CRC checksums : no
INFO: [mplex] Bit rate : 28672 bytes/sec (224 kbit/sec)
INFO: [mplex] Frequency : 44100 Hz
INFO: [mplex] Mode : 0 stereo
INFO: [mplex] Mode extension : 0
INFO: [mplex] Copyright bit : 0 no copyright
INFO: [mplex] Original/Copy : 1 original
INFO: [mplex] Emphasis : 0 none
INFO: [mplex] SYSTEMS/PROGRAM stream:
INFO: [mplex] rough-guess multiplexed stream data rate : 1403296
INFO: [mplex] target data-rate specified : 1411200
INFO: [mplex] Setting specified specified data rate: 1411200
INFO: [mplex] Run-in Sectors = 18 Video delay = 21600 Audio delay = 24603
INFO: [mplex] New sequence commences...
INFO: [mplex] Video e0: buf= 47104 frame=000000 sector=00000000
INFO: [mplex] Audio c0: buf= 4096 frame=000000 sector=00000000
INFO: [mplex] Padding : sector=00000000
INFO: [mplex] Scanned to end AU 123570
INFO: [mplex] STREAM e0 completed @ frame 123570.
++ WARN: [mplex] Discarding incomplete final frame MPEG audio stream c0!
INFO: [mplex] STREAM c0 completed @ frame 197319.
INFO: [mplex] Multiplex completion at SCR=463958400.
INFO: [mplex] Video e0: buf= 47104 frame=123570 sector=00257670
INFO: [mplex] Audio c0: buf= 1901 frame=197319 sector=00063329
INFO: [mplex] Padding : sector=00065601
INFO: [mplex] VIDEO_STATISTICS: e0
INFO: [mplex] Video Stream length: 593228030 bytes
INFO: [mplex] Sequence headers: 8447
INFO: [mplex] Sequence ends : 1
INFO: [mplex] No. Pictures : 123570
INFO: [mplex] No. Groups : 8447
INFO: [mplex] No. I Frames : 8447 avg. size 13151 bytes
INFO: [mplex] No. P Frames : 32745 avg. size 6007 bytes
INFO: [mplex] No. B Frames : 82379 avg. size 3464 bytes
INFO: [mplex] Average bit-rate : 1150800 bits/sec
INFO: [mplex] Peak bit-rate : 1281600 bits/sec
INFO: [mplex] BUFFERING min 17 Buf max 37356
INFO: [mplex] AUDIO_STATISTICS: c0
INFO: [mplex] Audio stream length 144325493 bytes.
INFO: [mplex] Syncwords : 197321
INFO: [mplex] Frames : 112752 padded
INFO: [mplex] Frames : 84569 unpadded
INFO: [mplex] BUFFERING min 15 Buf max 746
INFO: [mplex] MUX STATUS: no under-runs detected.
ls: /Users/randolph/Desktop/Video: No such file or directory
ls: Proj/ThomasVCD-*: No such file or directory
Encoding completed on Mon Nov 24 09:04:14 CST 2003
Well, it encoded the audio this time, unlike the last. But it somehow muxed a 565.7 MB video stream with a 137.6 MB audio to produce an 856.8 MB file ???!!!!. It also did not "auto-split," the file as requested, nor author the bin/que files.
I haven't played the MPEG file yet to find out what the extra 153MB are in the muxed file - seems very odd. But atleast the encode went farther with the decode with mencoder option checked.
Mr. Anderson
Mr. Anderson,
You're not reading Major's question carefully. He asked you several times to provide him with the information that appears in the main ffmpegX window just beneath the title bar (that says "ffmpegX 0.0.9a) and just above the "Open" and "Save As..." widgets. This information appears when you select the movie file you want to convert, but before you actually start the conversion.
Originally Posted by Mildew
"/Users/randolph/Desktop/Video Proj/Thomas.avi."
I provided the specs of this file earlier. It's an avi file(mpeg 4, xvid out put from ffmpeg 0.0.6g) that I wish to convert to MPEG 1.
Mr Anderson
Like Mildew and Major said, the info that they want from you is, what is written above the "open" & "save as" buttons ?
When you launch ffmpegX, the line above the "open" & "save as" buttons says: "Input can be VOB, MOV, DivX, MPEG, mp2/3, AC3, WAV file".
after open a file, this line changes to a info-line (i.e. VIDEO: mpeg-1, size: 352x288, 25.000 fps.) and thats exactly what the peeps here want 2 know from you (simple, or?)
Hope this help
Greetz U-MAN
I just have to say that this thread is hilarious! It belongs in a comedy sketch.
JTn64gba!Guest
This is funny. Very funny. 0.0.6 could rip from a disk?
Problems with ffmpegX
By KeepItSimple in forum MacReplies: 2Last Post: 5th Apr 2008, 20:46 -
Any problems with Xvid latest version and AVIReComp?
By Relayerman in forum Video ConversionReplies: 1Last Post: 30th Jan 2008, 10:00 -
Latest Version 2.5 & Problems with mpeg2 (files become too big) + AVI2M
By bc82 in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 29th Jan 2008, 08:31 -
Nvidia latest drivers giving me problems?
By Immortal25 in forum ComputerReplies: 7Last Post: 26th Nov 2007, 19:37 -
ffmpegx Problems! Help!
By The Sumerian in forum ffmpegX general discussionReplies: 4Last Post: 10th May 2007, 00:36
