    Oct 2003
    Athens, Greece
    I'm trying to install R6 Raiven Shield and when i click on setup a window comes up with this message:
    install shield wizard 6005 error:
    -close any running programs
    -empty your temp folder
    -check internet connections (internet based setups)
    Did anyone have that problem before?
  2. have you tried all the things listed in the error message?
    Oct 2003
    Athens, Greece
    I deleted everything in the TEMP folder, and no other application is running...i don't know what to do with the third option.I disabled the win xp firewall option but it didn't help.What "internet based setups" means?
    I also uninstalled Norton Antivirus.
  4. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    Typically it simply means that you should be able to go online. My second thought would be that it wants you online when you install, but if you can't have any other programs open, then you couldn't be online unless you're on broadband.
    Oct 2003
    Athens, Greece
    I tried that too.I' m connected (dial-up) and still the same message.I think its something about the install shield wizard because other people are having this problem too ( i checked in a relative forum).I also tried to install it from an image file but didn't work too...
  6. have you tried installing from safe mode?
    update internet explorer (and windows).
    i've also heard that for some programs you need to have the .NET framework installed.
    if everyone is having the same problem then i'm guessing there is actually something wrong with the program itself.
    Oct 2003
    Athens, Greece
    What is this .Net Framework and how can i get it ?
  8. You can download it from windows update
    If it's wet, drink it
    My DVD Collection
