I'm attempting to convert the Two Towers to VCD but my second discs isn't converting correctly. I'm using SmartRipper, DVD2AVI, TMPGenc. Disc 1 conversion went flawless, but the video on the second discs flickers. I played the vobs on PowerDVD and they seem fine.
System: P4 1.6, 512mb
Settings:
1) SmartRipper (same as Sefy's)
2) DVD2Avi 1.74 - Field Operation is none (ie not Forced Film), Decode to WAV and "48 -> 44.1KHz" is off. Info: 16:9m 29.970fps, Film.
3) TMPGEnc - 2.510
VCD - NTSC, Interlace, Bottom field first, 16:9 525 line (NTSC), Full Screen (keep aspect ratio 2). I have the VFAPI and DVD2AVI.vfp files
Any help or advice would be appreciated. thanks in advance!
I have exactly the same problem. I get flicker in the film starting about thirty minutes in. Using the same software. Have also tried Easy Divx get good picture but no sound. I am still trying to fix, will switch to DVD decrypter and dvd2avi 1.77, and DrDivx. Post after trying these.
Comforting to know this isn't just me. -
I have been enable to encode to Divx using DVD decrypter and DrDivx. I attempted to use the new DVD2AVI, but the sound file (AC3) was not recognized by TEMPGEnc. I could back encode to mpg using the Divx file as an audio source, but the sound problem is vexing. Also DrDivx makes a larger file than TEMPGEnc then virtual dub.
Why are cdr burn rings lighter than dvdr burn rings?
By yoda313 in forum Newbie / General discussionsReplies: 4Last Post: 27th May 2010, 17:55 -
lord of the rings Extended Editions? need very high quality rips
By dave_o in forum DVD RippingReplies: 3Last Post: 28th Jan 2010, 11:43 -
Lord Of The Rings (Extendet Edition) Demux - Remux Probs
By Summersun78 in forum Authoring (DVD)Replies: 3Last Post: 14th Nov 2009, 07:15 -
Ext. USB HD not visible
By juststarting in forum ComputerReplies: 4Last Post: 12th Jan 2009, 10:59 -
problems running avi files on ext player( clips shifting postions)
By auto7890 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 10th Aug 2007, 03:11
